DC Sound Lab
Well check this out i was thinking about buying 1 more lvl 5 18 for a total of 3 there shouldnt be a omh problem cause it will be 1 amp per speaker 3 subs wont mess things up right ?
dcaudio.jpg ALLAH's the most gracious, he made the universe the most spaciousSeen and heard in all places, but still appear facelessEmbraces all races, all caste and all casesIn every spec of life he's the substance of all tracesSMDsigbannr9.jpg
Correct, you could wire the subs down to whatever ohm load on each seperate amp and depending on your amp selection you might be able to master and slave the amps.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Get 3 RF T3kw(if you can find any) or T2kw or T4kw :D
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Wow, 3 18's. And lvl 5's too. I was thinking the other day about the same thing. But I was also thinking, "What if I had 3 lvl 5's powered by one Kicker Warhorse?" I wonder if one warhorse would be good enough?
Anyway, just thinking out loud. Hope to see your build soon.
what about the air space issues ?
still shouldnt be a problem. say one requires 4 cubes, you'd just make a box for 12 cubes (if you wanna use the common chamber method) the only concern you'd have would be using one amp to wire the 3 to like... thirds of an ohm and whatnot
with box rise an what not you shouldnt have a problem
2005 Nissan Altima 2.5 S
HU: AVIC-D2
Fronts: ARC Audio KAR KS6006 Components
AA Poly Mids/ CDT CW-19 Tweets in kicks
Front Amp: Profile AP400x2
Rear Fill: None
Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps)
AMP: RF t10001bd x2 (1400-1500 @ 1 ohm)
Wire: Welding Supply/Lighting Audio 1/0 Power/Ground
Zero Noise 2.0zn RCA (x2)
260 Amp Iraggi Alternator
Yea i just need to get the ok from Steve and find another 3k amp i think ill start looking =)
i cant wait to see build pics of this beast lol
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
