new box build not loud?!?
sbg
well i got the 45s cut and put in and also the port deflector in. drilled some more holes for wires to come out of the box. and re did my wireing to the subs. will put it all back in tomorrow and see if it sounds better.
so did you get them back in? are they sounding any better?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
well im going to have a coffee and take a shit and get to puting this back in the truck to see whats good. :Jim:
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Thank you for the play by play. I just COULDN'T go to bed until I knew your bowels were free of shit. Thank you for sharing me totext peacefully now hahaha.
Anyways, get to work, I want to know where the problem was. I can't imagine it's the box. it looks well built and the subs looks beefy enough to do some work. Cancellation is a bitch when you're out of phase
ok so i got the subs back in and did some test and they sounded way better now, i think i was out of phase and also the port 45 was needed. so i wanted to see if they would sound different so i turned the box around and now have the box with port up and subs to gate. and let me tell u NOW they sound awasome!!!!! way way better then port to gate and subs up! only down side of this is that i never painted the bottom of the box. witch is now the back. :rofl2:125C3578-4828-4053-8B88-BA336EAFADD9-7925DD6058B-EC0D-4468-B4AE-E11CBD9235BF-792
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
^^ and i cleaned up the wires after this pic
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
now i am thinking of runing @ .5 but not sure on it yet. as of now im at 2ohm for 600 watts rms, if i go down to .5 i will get 1000 rms. right now my voltage drop is not bad at all @2ohm going from 14.4 to 13.8 13.9 at full tilt at idle. i have ran a powerbass asa 1000.1 at .5 and never had a problem but have also ran a planet audio ap 1500.1 @.5 and it would shut down for a sec sometimes. on this same amp have now i was useing it on my 6-12 @ 1ohm and would get bad voltage drop. what u guys think?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Try some sound deadening
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
does it really sound better with the woofers half a millimeter away from the hatch?
  • Who's Online   0 Members, 0 Anonymous, 1167 Guests (See full list)
