stroupe79 Posted March 15, 2013 Report Posted March 15, 2013 I would do Big3, upgrade stock battery and get a battery bank in the rear started...105amp alt is small, I ran 2k total from 2amps on an 80amp stock alt with a stock battery and 3batts in the trunk...that was years ago running PPI amps, my shit would dim like hell even with the batteries... http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup)
Blue42 Posted March 15, 2013 Author Report Posted March 15, 2013 really didnt wanna spend the money to upgrade but i guess im gonna have to what about like 1000-1500 on 105amps untill i can get a bigger alternator i seen a 180amps on ebay for $300
Pioneerchuck Posted March 15, 2013 Report Posted March 15, 2013 Look at the idling amperage of that alt, I would go as far as to say it probably only puts out like 90A at idle and you probably have to be a near 5 grand for it to do anywhere close to its 180A claim.
Tarball Posted March 15, 2013 Report Posted March 15, 2013 Welcome to the SMD forums. Lots off great infromation and good quality folks here willing to help. I suggest you read up a bunch in the Electrical section. Use the search function also it will give you more information than you can imagine if used right. READ READ READ is the key, ask targeted questions, then when you have a solid understanding, then begin to plan to buy stuff. My advice - If you want to play in the 2k plus range - start with a quality H.O. alternator from a reputable company - output at idle is an important detail. Do Big 3 with alt then build out your electrical from there. If a quality H.O. alternator is out of your price range then consider changing your system goals around a bit. A well built 1k setup is going to sound better then a cheaply done 2k setup. Use the for sale section - lots of great deals, you can find a good alt for that ride (used) for a fair price that will likely fit your needs. If you wanna play you have to pay! Fortunately there are many different levels to play at and all are enjoyable in their own respect. peace CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
