Nick580 Posted March 15, 2013 Report Posted March 15, 2013 So I, in my state of ignorance, decided about a year ago to put down a layer of "Peel and Seal" in my car and now I need more deadener. Is it good to leave the old peel and seal in place and just cover over the top of it, or should I take it all out and apply my new stuff (Stinger Roadkill)? Let me know what you think.
WillPwn4Food Posted March 15, 2013 Report Posted March 15, 2013 Remove it if you can. You can cover a turd with gold, but it'll still smell like shit. Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus.
SnowDrifter Posted March 15, 2013 Report Posted March 15, 2013 Your biggest weakness will be that the roadkill will only adhere as good as the roofing material beneath it. I don't see it doing too great on a hot day with the added weight of a layer of deadened trying to pull it down. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
WadeTustian Posted March 15, 2013 Report Posted March 15, 2013 go over it, a little extra cant hurt! 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
Nick580 Posted March 15, 2013 Author Report Posted March 15, 2013 Remove it if you can. You can cover a turd with gold, but it'll still smell like shit. hahaha good analogy. and the wieght was some thing I was concerned about as well thanks.
WillPwn4Food Posted March 15, 2013 Report Posted March 15, 2013 If you ever have a doubt in your mind about anything, generally go with your gut. If you're concerned it might be a bad idea because it'll be too heavy, take it off. If you think snorting the 5 rows of cocaine is a bad idea... It probably is. Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus.
Nick580 Posted March 15, 2013 Author Report Posted March 15, 2013 That just means I have a lot of work to do... I guess it wouldnt matter on the floor pans though right? My main concern was the dampening effect. I dont guess that it would matter if the buytle stuff was directly connected to the to the pannels as opposed to the roofing material. Can you clear this up?
Nick580 Posted March 15, 2013 Author Report Posted March 15, 2013 The buytle is obviously better but would it make a difference if it were on the outside or inside of the peel and seal?
Noel989 Posted March 15, 2013 Report Posted March 15, 2013 Take it off how I see it your making better the ppeal and seal not the surface Build Log - http://www.stevemead...-cruiser-el-pt/
WillPwn4Food Posted March 15, 2013 Report Posted March 15, 2013 ^^^That's what I'd suggest. But that's just me. I'll be honest and tell you I have no idea which would actually sound better, but whenever someone mentions Peal n' Seal I'm like Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus.
