FeelDaBass Posted March 16, 2013 Author Report Posted March 16, 2013 I tried to supply as many details as possible. I put small 45s in the box with some bracing. My trunk has a 10 x 38 x 14 dimension limit right behind the backseat and behind that section, I could get a box with the dimensions 10 x 40 x 18 (depth x width x height). Any bigger than that and I'll have to make it more of a cube that is 30 inches wide so I could fit it into the trunk. Which would be 30 x 30 x 18.Using a T1 15" 1000 watt rms sub powered with a T1500-1bdCP @ 4 ohms (1000rms). I listen to mainly rap and dubstep, little rock. What other details would you like?I was going for more of the type of box I could do in my trunk...as I thought sealing this one off would be alright. But I've been told to just stick with a rear facing box. '98 Chrysler Concorde LXiPioneer DEH-80PRS (HU/processing)Rockford Fosgate T1652-S (components) for frontRockford Fosgate T1693 (6x9s) for rearRockford Fosgate T600-4 running thoseRockford Fosgate T1500-1bdCP running a Rockford Fosgate T1D215 15"in a 3.1 cu ft. net tuned to 34 hz (firing in cabin)Kicker PKD1 (0 & 4 AWG)stock 130 amp alt for now; One yellow top OptimaInstalled everything myself & built box (brother helped) Used a DD-1 to set gains. Build Log: http://www.stevemeadedesigns.com/board/topic/165894-first-build-accumulated-since-i-was-14/Just Pics: http://www.stevemeadedesigns.com/board/garage/vehicle/1463-chrysler-concorde-lxi/?tab=images
