bigger box question
Ryan929
So here is the suggestion, it would be best if you made a drawing to get familiar with the cutsheet specs, 4" PVC pipe for the ports:
Enclosure Specifications:
Fb = 33 Hz
Vb = 4 ft^3
External Height = 24 in
External Width = 50 in
External Depth = 12 in 76 deg.
External Depth2 = 6 in 76 deg.
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 24 3/4 x 50
Top = 4 1/2 , 4 11/16 x 50
Bottom = 10 1/2 , 10 5/16 x 50
Back = 24 x 50
Left & Right Sides =
Top = 4 11/16
Bottom = 10 5/16
Back = 22 1/2
Front = 23 3/16
Port Quantity and Dimensions:
Number of Ports = 3
Pipe Port Diameter = 4
Pipe Port Length = 20 1/4
External Length = 3 1/4
Assembly guide (generic dimensions):
If i put the dimensions into the torres the cut sheet will be the same right? Its easier for me to look at and understand
Also where exactly do i place the ports and how far from one another, and what is the bracing on the inside of the box?
The Torres cutsheet have a different assembly style and actually requires you to calculate your cuts so in addition to do a drawing you will have to determine your cuts sizes and angles yourself, it's maybe no big deal either way but I have already specified them so I think that's easier.
The distance between pipes side to side can be 1 1/2", the round braces can be 1 1/4" wooden dowel rods, the lower brace is just MDF cut to fit. The center of the cutout for the subs is 7 11/16" from the bottom end of the sheet.
Let me know if you have any more questions.
2 SA 12s in a ported box on about 2kw will be greatly improved by running a ported box, it will be in your best interest to do that instead of the sealed box....
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Haha i sure hope so as long as i do it all right lol
How do you think you are getting 6" top depth and 12" top depth in an S-10? Those are crazy numbers! At 24 for box height with 6" depth and 12" on the bottom, you are gonna be eating the dash every time you drive. Have I missed something? Is this possibly not for the S-10? And PLUS you are gonna add more depth for the spacing required to give the sub some breathing room? Where is this room coming from....
  • Who's Online   1 Member, 0 Anonymous, 479 Guests (See full list)
