Ryan929 Posted March 26, 2013 Author Report Share Posted March 26, 2013 Alright thanks man Link to comment Share on other sites More sharing options...
Joe X Posted March 26, 2013 Report Share Posted March 26, 2013 So here is the suggestion, it would be best if you made a drawing to get familiar with the cutsheet specs, 4" PVC pipe for the ports: Enclosure Specifications:Fb = 33 HzVb = 4 ft^3External Height = 24 inExternal Width = 50 inExternal Depth = 12 in 76 deg.External Depth2 = 6 in 76 deg.Cut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:Front = 24 3/4 x 50Top = 4 1/2 , 4 11/16 x 50Bottom = 10 1/2 , 10 5/16 x 50Back = 24 x 50Left & Right Sides =Top = 4 11/16Bottom = 10 5/16Back = 22 1/2Front = 23 3/16Port Quantity and Dimensions:Number of Ports = 3Pipe Port Diameter = 4Pipe Port Length = 20 1/4External Length = 3 1/4 Assembly guide (generic dimensions): Link to comment Share on other sites More sharing options...
Ryan929 Posted March 26, 2013 Author Report Share Posted March 26, 2013 If i put the dimensions into the torres the cut sheet will be the same right? Its easier for me to look at and understand Also where exactly do i place the ports and how far from one another, and what is the bracing on the inside of the box? Link to comment Share on other sites More sharing options...
Joe X Posted March 26, 2013 Report Share Posted March 26, 2013 The Torres cutsheet have a different assembly style and actually requires you to calculate your cuts so in addition to do a drawing you will have to determine your cuts sizes and angles yourself, it's maybe no big deal either way but I have already specified them so I think that's easier. The distance between pipes side to side can be 1 1/2", the round braces can be 1 1/4" wooden dowel rods, the lower brace is just MDF cut to fit. The center of the cutout for the subs is 7 11/16" from the bottom end of the sheet. Let me know if you have any more questions. Link to comment Share on other sites More sharing options...
Ryan929 Posted March 26, 2013 Author Report Share Posted March 26, 2013 Thanks you have haelped a lot so far im about to start cutting. Where do i place the piece of mdf that is inside the box? Link to comment Share on other sites More sharing options...
Ryan929 Posted March 26, 2013 Author Report Share Posted March 26, 2013 also why does this say two measurements for the top: Top = 4 1/2 , 4 11/16 x 50 The 4 1/2 and the 4 11/16 Link to comment Share on other sites More sharing options...
Ryan929 Posted March 26, 2013 Author Report Share Posted March 26, 2013 Also how far away from the edge to i place the first port all the way to the right Link to comment Share on other sites More sharing options...
stroupe79 Posted March 26, 2013 Report Share Posted March 26, 2013 2 SA 12s in a ported box on about 2kw will be greatly improved by running a ported box, it will be in your best interest to do that instead of the sealed box.... http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
Ryan929 Posted March 26, 2013 Author Report Share Posted March 26, 2013 2 SA 12s in a ported box on about 2kw will be greatly improved by running a ported box, it will be in your best interest to do that instead of the sealed box.... Haha i sure hope so as long as i do it all right lol Link to comment Share on other sites More sharing options...
CleanSierra Posted March 26, 2013 Report Share Posted March 26, 2013 How do you think you are getting 6" top depth and 12" top depth in an S-10? Those are crazy numbers! At 24 for box height with 6" depth and 12" on the bottom, you are gonna be eating the dash every time you drive. Have I missed something? Is this possibly not for the S-10? And PLUS you are gonna add more depth for the spacing required to give the sub some breathing room? Where is this room coming from.... Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
