Ryan929 Posted March 26, 2013 Author Report Posted March 26, 2013 Thanks you have haelped a lot so far im about to start cutting. Where do i place the piece of mdf that is inside the box? Place the brace towads the center: In regards to the dual depths is because those parts support the 76 deg. slanted baffle, take a look: Ohhh okay i get it And as for when i get the wood all cut and start putting it together how do i do that do i glue it first then drill screw holes and put screws in or what?
Ryan929 Posted March 26, 2013 Author Report Posted March 26, 2013 Hahaha, proceed then. Im interested to see the results. 2 SA12s in.a regular cab S-10 should get downright nasty. Haha, i cant wait im excited
Ryan929 Posted March 26, 2013 Author Report Posted March 26, 2013 How do i cut those angles off the top and bottom pieces?
CleanSierra Posted March 26, 2013 Report Posted March 26, 2013 With a compound mitre saw. Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted March 26, 2013 Report Posted March 26, 2013 Or a circular saw that can change plane. Im not the one you want to try to troll. Just a fyi for you.
Ryan929 Posted March 26, 2013 Author Report Posted March 26, 2013 Or a circular saw that can change plane. I have that but how do i know what to set it at the 76 degrees?
CleanSierra Posted March 26, 2013 Report Posted March 26, 2013 With a compass. You're does not have measurements printed on it? Im not the one you want to try to troll. Just a fyi for you.
Ryan929 Posted March 26, 2013 Author Report Posted March 26, 2013 Progress so far nothing is glued or screwed down
Ryan929 Posted March 27, 2013 Author Report Posted March 27, 2013 I got the angles cut and all that now how do i put it all together do i put the glue on then drill holes and put screws in or what?
