Bump4life Posted March 25, 2013 Report Posted March 25, 2013 i havent had type rs for a while. sorry about confusion with which generation i had. seems they always change their subs haha. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
lilflippy Posted March 26, 2013 Author Report Posted March 26, 2013 It actually depends on how much power you run to it. Say you have a 500w amp, and you want the most output from a 1000w sub, then you go for max or above the recommended size. If you want to run 1500w to a 1000w sub, you go smaller than recommended size because it gives the sub more cone control. Hhm right now im at 1.38 cu ft net after sub after port displacement and tuned to 35Hz.. Just wondering if ill get a little bit more by going to 1.5 cu ft net after port displacement and tuned to 35Hz
caraudionoob Posted March 26, 2013 Report Posted March 26, 2013 Hhm right now im at 1.38 cu ft net after sub after port displacement and tuned to 35Hz.. Just wondering i ill get a little bit more going to 1.5 cu ft net after port displacement and tuned to 35Hz What's your amp? Also, list the max dimensions for the box. Someone here (probably Joe) can whip you up a design easily.
lilflippy Posted March 26, 2013 Author Report Posted March 26, 2013 Hhm right now im at 1.38 cu ft net after sub after port displacement and tuned to 35Hz.. Just wondering i ill get a little bit more going to 1.5 cu ft net after port displacement and tuned to 35Hz What's your amp? Also, list the max dimensions for the box. Someone here (probably Joe) can whip you up a design easily. I have a Alpine MRP-M2000
lilflippy Posted March 27, 2013 Author Report Posted March 27, 2013 Fifth generation Type Rs work in less net volume than previous generations their spec range tops at 1.5 cubes per chamber and that's what I would recommend if you are going to push full rated or above rated power. @Joe X what port tuning would ya recommend?
Joe X Posted March 27, 2013 Report Posted March 27, 2013 33-34 Hz is the range I'd stay within for low tuned music and in an extcab, subs up/port diver's side if you are wide enough for port clearance.
lilflippy Posted March 27, 2013 Author Report Posted March 27, 2013 33-34 Hz is the range I'd stay within for low tuned music and in an extcab, subs up/port diver's side if you are wide enough for port clearance. OK by the way do you make boxes? And yes i have enough room back there.
lilflippy Posted March 28, 2013 Author Report Posted March 28, 2013 @Joe X "port diver's side" Do you mean the port on driver side facing the seat?
Joe X Posted March 29, 2013 Report Posted March 29, 2013 Like this: If you want some calculations done for you let me know your max dims for a box. Subs can also be done front, port can also be done up.
lilflippy Posted March 29, 2013 Author Report Posted March 29, 2013 Like this: If you want some calculations done for you let me know your max dims for a box. Subs can also be done front, port can also be done up. Also can ya build me a box? And ship it ?
