bass hits harder with my trunk open! WHY???
matt6288
yes that makes absolutely perfect sense. so I need to d a better job sealing it off from the back where I have my amp rack so there are no leaks. should I close off the front of my box as well with another piece of plywood or would that be worse
the reason it does that is because it is cancelling out (when your trunk is shut). Bass is firing forward, then some of it is leaking backward through your leaky rear deck and the openings around the box itself. It travels backwards, hits the back of the car and then comes forward again but now its playing bass 180deg out of phase..basically reverse (to make it easier to explain). When you play a sound, and the same sound exactly the opposite, you get cancellation and the bass is reduced. Sorta like hooking up two subwoofers up out of phase, you know what i'm talking about? Anyway, When you open the trunk, the leaky bass is going backwards, and out of the car instead of bouncing back into the cabin.
This is why a car with a box aimed backwards typically sounds better then aimed forward (non properly anyway). Because the bass rolls off of the woofer and goes directly into the cabin, you get no cancellation. For a forward firing box to work properly, it needs to be sealed off from the trunk so no bass goes backwards at all, giving it no chance to cancel out.
You should maybe build a new box, sealed or ported. Doesn't matter. But seal that one off from the trunk. Also seal all the holes in your rear deck. $100 says that's where your current leak is. Rear decks have a bunch of holes in them and I noticed your beauty panel looks to be in front of where the rear deck stops at the back window. Might wanna look into sealing off the rear deck completely and revisiting your beauty panel on your amp rack that "seals off" right now. That is if you don't wanna rebuild your box.
If you do redo your box. Leave your beauty panel. And seal your rear deck and seal the subs off firing forward.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
you have a all build log here
http://www.stevemeadedesigns.com/board/topic/162367-aq-build-01stratus-sealed-off-trunk-vid-page6/page-5
its great build and you can get a couple good ideas!!!
Thanks for that!! :D I thought that looked familiar!
you should thank yourself for a great work ;)
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
that looks great I was gonna do something similar to that I got the plywood ready for it just haven't installed it yet but by the looks of it I shoulda done that one first so ill be working on that weds.
thats what u wanna do :)
yea i agree with just building a new box that totally fills that space get you some expand foam and that second skin. and seal it up . it will be alot louder and cleaner sounding. btw, how is the five hundred? im thinking about getting one in the next month or so...
  • Who's Online   1 Member, 0 Anonymous, 1570 Guests (See full list)
