Subs hitting the seat
Will my DC Audio level 3s get damaged if they hit the back of my seat in my truck?
i would say yes i had the same issue so i flush mounted my subs and put little pieces of wood around the subs to move the seat out if the way not the prettiest but it worked
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
damn :/ idk if ill have the room to flush mount them but ill see
if not flush mounting what about like a speaker grill and it can just push the back of the seat so it doesnt hit the sub could that work for ya? What truck btw?
My setup,
Digital Designs M80
Kenwood x-696
SHCA 0 gauge
single cab 1999 s10 5 speed manual so no center council bc its a bench seat
i had the same problen cuz of the bench seat hopefully making a grill ir something like that will fix it good luck man
My setup,
Digital Designs M80
Kenwood x-696
SHCA 0 gauge
I've run subs for years that hit the back.if the seat and never had one fail because of it. You may experience some surround rub and cosmetic issues, but mechanically the sub should be able to function properly for years mounted like that. Which Level 3s are you wanting to run behind the seats, like what size?
Wouldn't that cause problems with the coil not being able to moving correctly out? Like it stopping the coil from fully moving out.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
How hard are we talking about hitting the seat? like are you not allowing it to move at all? It's got to have some space in front of it, it can't be buried into the back of the seat. You need more room it appears, OP. Also if you're trying to squeeze 2 12s, good luck. I'm not sure what kind of size box you're prepared to build, or legroom you're giving up.
  • Who's Online   0 Members, 0 Anonymous, 732 Guests (See full list)
