Mobileaudio25 Posted March 27, 2013 Report Posted March 27, 2013 I have 2 batteries on opposite sides of my trunk, so I can't use bus bars. Should I ground each battery out individualky or should I not ground out the first battery in the bank and do a - to - run and ground out the last battery in the bank
Wicks Posted March 27, 2013 Report Posted March 27, 2013 Whatever is most convenient for you. As long as your connecting method can handle the required electrical current. In a car you have positive and negative (0V). There really is no "ground" as you have in your house. Wiring to your chassis is really just a BIG wire that is used as a current return from the front to back of your vehicle. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
OrzechNJ Posted March 28, 2013 Report Posted March 28, 2013 I would ground them separately to the chassis and connect them to each other + make one negative run from front to back.. never too much grounding ! sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
Hunters21w Posted March 28, 2013 Report Posted March 28, 2013 Connect the 2 back batteries negative to negative, pos to pos. Then connect your front battery to the first back battery the same way. 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Carbon Posted March 28, 2013 Report Posted March 28, 2013 I would ground them separately to the chassis and connect them to each other + make one negative run from front to back.. never too much grounding ! X2. You can never have too much ground
Wicks Posted March 28, 2013 Report Posted March 28, 2013 I would ground them separately to the chassis and connect them to each other + make one negative run from front to back.. never too much grounding ! X2. You can never have too much ground Absolutely agree. OP, Here's something else to keep in mind. Current flows in a loop. The current in the positive wire equals the current in the negative wire. You're always limited by the smallest wire diameter in the system. If you have one run of 0ga for a positive run and three runs of 0ga for negative then those extra two negative wires won't help much because the system is limited by the one positive wire. If you beef up your grounds it's also a good idea to beef up the positive runs as well to get full benefit. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
OrzechNJ Posted March 28, 2013 Report Posted March 28, 2013 I would ground them separately to the chassis and connect them to each other + make one negative run from front to back.. never too much grounding ! X2. You can never have too much ground Absolutely agree.OP, Here's something else to keep in mind. Current flows in a loop. The current in the positive wire equals the current in the negative wire. You're always limited by the smallest wire diameter in the system. If you have one run of 0ga for a positive run and three runs of 0ga for negative then those extra two negative wires won't help much because the system is limited by the one positive wire. If you beef up your grounds it's also a good idea to beef up the positive runs as well to get full benefit. Much better explained here ! sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
Mobileaudio25 Posted March 29, 2013 Author Report Posted March 29, 2013 Sounds good, I'll keep them grounded separately !
