Fuse Questions
for some reason, fuses seem to confuse me. I have a few questions:
1. If an amplifier requires a 250 amp fuse, does that mean that its amperage draw is 250 amps? and thus you would need a 250 amp alternator? (obviously it would be more to accomodate the vehicle draw, but I'm speaking hypothetically).
2. If you run two runs of 1/0awg wire to an amplifier, would you fuse both runs with a fuse that is half of the amplifier's fuse rating? i.e. an amplifier that requires a 300 amp fuse, would each run of power wire be fused with a 150 amp fuse?
1990 300ZX
Alpine MRX-M100
RE SE 12's
Alpine CDE-121 Head Unit
Alpine Type-S 6.5" Components
Alpine KTP-445
Soon to come:
Alpine CDE-136BT
Big 3 with Knu Kolossus
XS Power Batt up front
HO alt
Crescendo BC2000
SSA Zcon 15
Crescendo Concerto speaker amp
Crescendo mids and super tweeters
1. No and yes. It's a give and take thing. It's a combination of battery and alt providing power. You can have enough alt power to fully supply the amp's needs, but it's usually easier and cheaper to use batteries to back up the alt. that's the short answer.
2. Fuse to the wires rating typically, not the amps. So in your example, use 2 300amp fuses.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Thanks for the help!
So there is nothing wrong with having too large of a fuse? This doesn't put the amplifier at any risk?
1990 300ZX
Alpine MRX-M100
RE SE 12's
Alpine KTP-445
Soon to come:
Alpine CDE-136BT
HO alt
Crescendo BC2000
SSA Zcon 15
Power cable runs should be fused to the current rating of the wire.
Amps should be fused to their power rating.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Well isn't the power cable's fuse also the amp's fuse? I don't see where you're coming from
1990 300ZX
Alpine MRX-M100
RE SE 12's
Alpine KTP-445
Soon to come:
Alpine CDE-136BT
HO alt
Crescendo BC2000
SSA Zcon 15
the amps usually have a fuse on the amp. when you are putting the fuse at the beginning of the wire close to the battery that is protecting the wire for any shorts in the wire or over drawing the wire(pulling to much current). so thats why you get a fuse that is rated for what the wire is rated for. i you run wire that is rated for 125 amps thats the size fuse you should go with at the start of the wire run or smaller. if you go with a bigger fuse then the wire isnt protected.
Normally, the power wire current capacity is greater than the fuse rating of the amp. In the case of one amp, you can use the size of fuse recommended for the amp on the wire, this will protect the wire and the amp. and if you have 2 runs of power wire then run both runs to the one fuse rated for the amp.
If you have more than one amp then use a fused distribution block, where each output is fused for the specific amp's capacity and the main power wire or wires into the distribution block is fused to the capacity of the wire.
The above applies to amps that require external fusing.
The amps I've been considering are the AQ2200 and Crescendo BC2000, neither of which have fuses on the amp. So what do I do in this case?
1990 300ZX
Alpine MRX-M100
RE SE 12's
Alpine KTP-445
Soon to come:
Alpine CDE-136BT
HO alt
Crescendo BC2000
SSA Zcon 15
If you have more than one amp then use a fused distribution block, where each output is fused for the specific amp's capacity and the main power wire or wires into the distribution block if fused to the capacity of the wire.
Thanks for the good advice. So if I'm running an amp that doesn't have a fuse in it, I should fuse to the amps fuse rating? Because in this case it protects the amp and the wire? (being that the fuse rating is at or lower than the wire's rating)
1990 300ZX
Alpine MRX-M100
RE SE 12's
Alpine KTP-445
Soon to come:
Alpine CDE-136BT
HO alt
Crescendo BC2000
SSA Zcon 15
  • Who's Online   1 Member, 0 Anonymous, 1196 Guests (See full list)
