flwatersaver Posted March 28, 2013 Report Share Posted March 28, 2013 THIS IS FOR INFORMATION ONLY PLEASE DO NOT POST YOUR OPINIONS. Background InfoLoad tester - sanp-onThe load tester uses a turn dial that has to be cranked and held in place. We did our best trying to hold it at 500amp load for 30secs but some variations occur which you can see in the video. Please do not get upset at these varations but you can use them to form any opinion you want.After the video ended a one min timer (started after load) told use when to take the picture for return to voltage.We took measurements, weight, and pad size for each battery.how pad size was taken. My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI Link to comment Share on other sites More sharing options...
flwatersaver Posted March 28, 2013 Author Report Share Posted March 28, 2013 Model - Duracell 31AGMgroup -31weight - 66.6lbs+ post pad - .925instarting V - 12.905 sec load - 505amps 9.99v15 sec load - 510amps 9.95v25 sec load - 493amps 9.97v30 sec load - 524amps 9.83vinstant return - 12.32v1 min return - 12.57v 1 min return My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI Link to comment Share on other sites More sharing options...
flwatersaver Posted March 28, 2013 Author Report Share Posted March 28, 2013 Model - XS Power XP3000group -31weight - 71.2+ post pad - .550instarting V - 13.185 sec load - 512amps 10.0315 sec load - 502amps 9.88v25 sec load - 502amps 9.75v30 sec load - 503amps 9.69vinstant return - 12.63v1 min return - 12.88v one min return My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI Link to comment Share on other sites More sharing options...
flwatersaver Posted March 28, 2013 Author Report Share Posted March 28, 2013 THIS ONE WILL BE RETESTED WITH A BETTER CONNECTION Model - Optima D34/78group -34weight - did not weigh+ post pad - .886instarting V - 12.665 sec load - 527amps 9.0215 sec load - 526amps 8.8120 sec load- 512amps 8.79v25 sec load - DNF30 sec load - DNFinstant return - DNF1 min return - DNF20 secs into testing the battery was popping, hissing, smoking, and then upon melting we shut it off. Even the top terminals were super hot. The battery did survive and still works but I would not recommend this battery for this kind of load. ( Warning - a 500amp load is not recommended for any group 34 at all) My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI Link to comment Share on other sites More sharing options...
flwatersaver Posted March 28, 2013 Author Report Share Posted March 28, 2013 Model - XS power D3400group -34weight - 47.2+ post pad - .787instarting V - 13.085 sec load - 508amps 9.92v15 sec load - 555amps 9.52v25 sec load - 505amps 9.61v30 sec load - 526amps 9.45vinstant return - 12.39v1 min return - 12.64v My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI Link to comment Share on other sites More sharing options...
flwatersaver Posted March 28, 2013 Author Report Share Posted March 28, 2013 Model - Optima D31Tgroup -31weight - 59.7+ post pad - .916instarting V - 12.95v5 sec load - 493amps 10.57v15 sec load - 492amps 10.58v25 sec load - 530amps 10.45v30 sec load - 526amps 10.45vinstant return - 12.25v1 min return - 12.41v My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI Link to comment Share on other sites More sharing options...
flwatersaver Posted March 28, 2013 Author Report Share Posted March 28, 2013 Model - XS Power D3100group -31weight - 74.8+ post pad - .958instarting V - 13.16v5 sec load - 505amps 10.59v15 sec load - 505amps 10.65v25 sec load - 530amps 10.56v30 sec load - 519amps 10.57instant return - 12.57v1 min return - 12.76v My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI Link to comment Share on other sites More sharing options...
n8ball2013 Posted March 28, 2013 Report Share Posted March 28, 2013 two things that optima is resting way low. Its pretty much kicked at its resting voltage. They have been known to not handle nearly as much crrent draw through the side mounts. do it on the top mounts and see. It wont make that much of a difference im sure but ive got some extensive ahdns on with them. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
SnowDrifter Posted March 28, 2013 Report Share Posted March 28, 2013 Great tests! Thank you! Were the batteries charged before hand or were they just pulled out of a car/off the shelf? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
flwatersaver Posted March 28, 2013 Author Report Share Posted March 28, 2013 two things that optima is resting way low. Its pretty much kicked at its resting voltage. They have been known to not handle nearly as much crrent draw through the side mounts. do it on the top mounts and see. It wont make that much of a difference im sure but ive got some extensive ahdns on with them. All charged recently. The group 34 optima was pulled from my pos s10 truck. and was not charged. We are working on getting more batteries. My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI Link to comment Share on other sites More sharing options...
