Battery test thread
THIS IS FOR INFORMATION ONLY
PLEASE DO NOT POST YOUR OPINIONS.
Background Info
Load tester - sanp-on
The load tester uses a turn dial that has to be cranked and held in place. We did our best trying to hold it at 500amp load for 30secs but some variations occur which you can see in the video. Please do not get upset at these varations but you can use them to form any opinion you want.
After the video ended a one min timer (started after load) told use when to take the picture for return to voltage.
We took measurements, weight, and pad size for each battery.
how pad size was taken.
Model - Duracell 31AGM
group -31
weight - 66.6lbs
+ post pad - .925in
starting V - 12.90
5 sec load - 505amps 9.99v
15 sec load - 510amps 9.95v
25 sec load - 493amps 9.97v
30 sec load - 524amps 9.83v
instant return - 12.32v
1 min return - 12.57v
1 min return
Model - XS Power XP3000
group -31
weight - 71.2
+ post pad - .550in
starting V - 13.18
5 sec load - 512amps 10.03
15 sec load - 502amps 9.88v
25 sec load - 502amps 9.75v
30 sec load - 503amps 9.69v
instant return - 12.63v
1 min return - 12.88v
one min return
THIS ONE WILL BE RETESTED WITH A BETTER CONNECTION
Model - Optima D34/78
group -34
weight - did not weigh
+ post pad - .886in
starting V - 12.66
5 sec load - 527amps 9.02
15 sec load - 526amps 8.81
20 sec load- 512amps 8.79v
25 sec load - DNF
30 sec load - DNF
instant return - DNF
1 min return - DNF
20 secs into testing the battery was popping, hissing, smoking, and then upon melting we shut it off. Even the top terminals were super hot. The battery did survive and still works but I would not recommend this battery for this kind of load. ( Warning - a 500amp load is not recommended for any group 34 at all)
Model - XS power D3400
group -34
weight - 47.2
+ post pad - .787in
starting V - 13.08
5 sec load - 508amps 9.92v
15 sec load - 555amps 9.52v
25 sec load - 505amps 9.61v
30 sec load - 526amps 9.45v
instant return - 12.39v
1 min return - 12.64v
Model - Optima D31T
group -31
weight - 59.7
+ post pad - .916in
starting V - 12.95v
5 sec load - 493amps 10.57v
15 sec load - 492amps 10.58v
25 sec load - 530amps 10.45v
30 sec load - 526amps 10.45v
instant return - 12.25v
1 min return - 12.41v
Model - XS Power D3100
group -31
weight - 74.8
+ post pad - .958in
starting V - 13.16v
5 sec load - 505amps 10.59v
15 sec load - 505amps 10.65v
25 sec load - 530amps 10.56v
30 sec load - 519amps 10.57
instant return - 12.57v
1 min return - 12.76v
two things that optima is resting way low. Its pretty much kicked at its resting voltage.
They have been known to not handle nearly as much crrent draw through the side mounts. do it on the top mounts and see. It wont make that much of a difference im sure but ive got some extensive ahdns on with them.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Great tests! Thank you!
Were the batteries charged before hand or were they just pulled out of a car/off the shelf?
All charged recently. The group 34 optima was pulled from my pos s10 truck. and was not charged. We are working on getting more batteries.
  • Who's Online   0 Members, 0 Anonymous, 483 Guests (See full list)
