Tarball Posted March 31, 2013 Report Posted March 31, 2013 I noticed this back in the day. On the amp i tested with (Kenwood PS-400M) splitter from one jack was the same as just one jack. My theory is that when mono sub amps hit the market they just plugged in to the existing stereo environment so the internals expect 2 channels and pull them together into one. The Brazillian market has "evolved" on its own so to speak - same reason we have all those unique species in Madagascar. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
HunterJohnson Posted March 31, 2013 Report Posted March 31, 2013 I think they provide the option of two, just incase you run ur amp as mid bass in the front? Since sub amps can usually play to 350hz But ur right all subs are mono Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
