2 Questions about my HID Lights
So how do you have the lights working if you disconnected it from the harness? Are you using a dedicated switch and relays for the ballasts? Almost all relay kits have it where you plug the stock wiring in one part of the relay kit and this connection is what energizes the relay to make the power flow through from the battery to the ballast connections offered from the relay kit itself.
As for your resistance I am not too sure what you need for resistance. Different cars have different ranges that they check for the bulb out warning
i have them connected to switched power in my fuse box. only way to eliminate flickering for me
How about the turning them on with the vehicle off? There could be a chance your motors for the window dont draw a ton of current like mine do to make the voltage drop.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
thats what i do usually and only one fires up 75% of the time
i tried doing the window trick and it worked. ill try it everyday and see if it works
  • Who's Online   0 Members, 0 Anonymous, 1569 Guests (See full list)
