BassMunky Posted April 4, 2013 Report Posted April 4, 2013 make sure ground to frame by itself and not with another wire or ground to the amp ground. No no will cause unwanted noise Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
ric006 Posted April 4, 2013 Report Posted April 4, 2013 you guys need to buy purly 12v fan, its for 12volt applications the one above is a computer fan that is a mearly 12 volts with a 5v input to it which is the yellow wire that controls fan speed. in the car you dont need that not to mention i like the metal casing vs the plastic
ImaNoob Posted April 4, 2013 Author Report Posted April 4, 2013 make sure ground to frame by itself and not with another wire or ground to the amp ground. No no will cause unwanted noise Yeah its in my ground distro block...So distro block is a no no ? you guys need to buy purly 12v fan, its for 12volt applications the one above is a computer fan that is a mearly 12 volts with a 5v input to it which is the yellow wire that controls fan speed. in the car you dont need that not to mention i like the metal casing vs the plastic Yeah im not using the yellow...I thought all 12 volt fans were created equal..Im going to look into those you posted 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
BassMunky Posted April 5, 2013 Report Posted April 5, 2013 that ok as long as ur not connecting it straight to the amp. just listen and hear if there any wine noise and might be from the fan. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
STEvil Posted April 7, 2013 Report Posted April 7, 2013 you guys need to buy purly 12v fan, its for 12volt applications the one above is a computer fan that is a mearly 12 volts with a 5v input to it which is the yellow wire that controls fan speed. in the car you dont need that not to mention i like the metal casing vs the plastic Yellow wire is either a tachometer wire or speed control wire, not a 5v wire. Nothing wrong with fans that 3 or 4 wires as long as you connect the correct two wires. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
