moegej Posted April 5, 2013 Report Posted April 5, 2013 I plan on getting a pair of the new Sundown x series 10's when they come out. and im just wondering, how much electrical is needed to run at .5ohm? i gonna be ordering a new mechman hybrid g series 270 that does 165 amps at idle. how many batteries will i need to be safe? if its gonna end up being quite a bit of money to run at .5 i might just stick with running at 1. i was just curious how much electrical it will actually take. 06 v6 Mustangbig 3Mechman 270 Hybrid G2 interstate batteriesBC3500 wired at 12 Sundown x-10 D4's
Miguels Posted April 5, 2013 Report Posted April 5, 2013 if you wanted more power then you should have just gotten the bc5500 get 3 XS d3100 my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
SnowDrifter Posted April 5, 2013 Report Posted April 5, 2013 I have a DC 270 and can play all day with just a pair of 40ah batteries. Drop to 13v at idle, hold 14+ revving or driving. Charging at 14.2 You will want a bit more battery reserve though, since I have quite a bit more idle output. IMO 3 d3100s is a bit overkill, but overkill won't hurt ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
moegej Posted April 5, 2013 Author Report Posted April 5, 2013 i got it for a good price froma guy on here. im happy with it. thanks for the reply 06 v6 Mustangbig 3Mechman 270 Hybrid G2 interstate batteriesBC3500 wired at 12 Sundown x-10 D4's
moegej Posted April 5, 2013 Author Report Posted April 5, 2013 so maybe 2 3100's? 06 v6 Mustangbig 3Mechman 270 Hybrid G2 interstate batteriesBC3500 wired at 12 Sundown x-10 D4's
Kyblack76 Posted April 5, 2013 Report Posted April 5, 2013 Die hard gold, and stock alt. Id run it at quarter ohm nom,.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Nate Futuristic Posted April 5, 2013 Report Posted April 5, 2013 im running a saz3500d @ .35 on 5 group 34s, two runs of power and ground (CCA) stock alt and only the power wire from the alt to the front battery in 1/0 (1/3 of the big 3) stock alt is like 136a max close to maybe 50-70a at idle gain set low warm voltage 14.1 idle voltage drop is in 12.4s FAST revving to 1500+ (never over 2k) voltage drops to 13.1+ depending on what song id recommend at least a 200-250a alt and 2 or 3 group 34s or bigger if you want decent reserve for daily or MAX ouput for burps down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
SnowDrifter Posted April 5, 2013 Report Posted April 5, 2013 so maybe 2 3100's? Should be good. Plus whatever's under the hood. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Nate Futuristic Posted April 5, 2013 Report Posted April 5, 2013 Die hard gold, and stock alt. Id run it at quarter ohm nom,.... dont forget 4 gauge power and grounds and no fusing down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
EVL-100 Posted April 5, 2013 Report Posted April 5, 2013 I have the same amp, wired at 1ohm, mechman 250amp alt, 2 xs d3100's, 2 runs + 2 runs - knukonceptz cca, while driving around I dont drop below 13v, in my opinion this is just enough I plan on adding another d3100
