bassaddiction Posted April 5, 2013 Report Posted April 5, 2013 need u guys to help me out with a box design. trunk box facing front of car subs and port forward use - spl on music mostly rap and dubstep max measurments 30 deep 39 wide 19 tall there going to be on a old school rf t1000bd, puts out like 1400 rms slot port thanks for you input, i hope it gets louder then my aq lol i will take picks when done and videos thanks again
bassaddiction Posted April 5, 2013 Author Report Posted April 5, 2013 joe x help me out, the last box was sick
Joe X Posted April 6, 2013 Report Posted April 6, 2013 Here is a suggestion subs/port frontwards or backwards: Enclosure Specifications:Fb = 33.5 HzVb = 4.1 ft^3External Height = 14 inExternal Width = 37.5 inExternal Depth = 22 inPort Width = 4 1/2 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2x Front = 16 1/2 x 12 1/2Back = 37 1/2 x 12 1/2Left & Right Sides: 20 1/2 x 12 1/2Top & Bottom = 37 1/2 x 22Shared Port Internal Assembly Parts:2 x Front to Back = 18 1/4 x 12 1/22 x Extension = 1 3/8 x 12 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 4 1/2" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested.
bassaddiction Posted April 6, 2013 Author Report Posted April 6, 2013 thanks man looks good hopfully it will fit i didnt measure it lol if its not a big deal can u find out the 45 in port thanks again
Joe X Posted April 6, 2013 Report Posted April 6, 2013 Measure the width as it's near your spec, here is the guideline to do the 45s inside the port: Happy building
bassaddiction Posted April 10, 2013 Author Report Posted April 10, 2013 didnt fit fits side ways tho. is there any problems with having it like that.
thefourth Posted April 10, 2013 Report Posted April 10, 2013 LOL Measure twice, cut once. Lesson learned? Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
bassaddiction Posted April 10, 2013 Author Report Posted April 10, 2013 LOL Measure twice, cut once. Lesson learned? lesson learned here is measure it your self, lol wich i should have done. box came out good any way lol
Joe X Posted April 10, 2013 Report Posted April 10, 2013 Try to see if you can get it in properly from the backseats . Great building job anyway.
