Static hiss?
SnowDrifter
I just noticed this today. I can hear a static hiss coming through my super tweets. It's faint, but it's there. Doesn't matter whether the RCAs are plugged in or not, nor whether the car is on or off.
It's not alt whine, but it sounds like a white noise
The amp inputs are unterminated and therefore floating.
Like you said it's probably picking up random white noise from the air.
Short the two input conductors and I bet it goes away.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Connections are tight. I went out there with a wrench and made sure of it lol.
No frays on the wires going to the tweets either
What so do you mean by short them?
The inputs to the amp could cause this!????
Short the RCA center conductor to the outside conductor with some wire, a shorting plug, a relatively low ohm resistor...
Is the noise a problem?
You said only when the signal cables are unplugged so it shouldn't be a problem.
I'm sure a lot of amps do this when disconnected.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
It does it regardless of whether the RCAs are plugged in or not
What does your TV do when it's modulator (off-air signal) has no signal?
Snowy white and black screen (white noise), right?!
Same thing here.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
How would I short out the RCAs while they are plugged in?
Are you sure that would work? Seems like it would screw up the source when it's putting a signal into a couple ohms vs. 20k ohms
  • Who's Online   0 Members, 0 Anonymous, 502 Guests (See full list)
