New car, new build, need advice
First and foremost, I'd like to thank everybody here that has inspired me with their amazing work. Got a new car, 2005 Acura Tl, planing on installing the sound equipment from the previous car including:
Focal 165a1 components, for front
Focal IC 160, for back
Boston acoustics GTA 704 amp, for mids and highs
AQ 1200w rms amp, for subs
2 obsidian Audio 12 inch subs
Wire: 0 awg power, rca, speaker, etc.
and a new Pioneer head unit
A few questions now follow... I'm planing on running about 1400 watts, so will a 220 amp alt be enough? For a battery, I was thinking xs power d925 in conjunction with my stock battery, do I need an isolator? Damplifier, any significant difference between second skin pro b-stock and pro bulk? Pretty sure the head unit is going to be a custom job. Can anybody point me in the right direction of how to design a dash mold? Would blue leds around the head unit be too difficult for a novice? What about carbon fiber (to match interior)? How should i secure my sub box?
Thanks in advance! I'm pretty new at this.
A 220A alt should be fine for 1400 watts as long as you have the big 3 upgrade done and proper grounds. As far as the battery, I would not use the stock battery with an XS battey as the stock one has a lower resting voltage and will likely leech off of the XS battery. I am not a fan of Isolators. You would be better off replacing your stock battery with the largest XS that would fit. Which is the XS Power D2400 for you car.
http://4xspower.com/bci_group/24F/
The second skin B-stock is the exact same product as the regular. It's just that some peices may have inconsistencies in the adheisive or it may be a bit harder to remove the backing. Other than that they are both excellent.
Exactly what he said ^
Car: 2000 Honda CRV
Battery: XS Power D5100R
Alternator: Stock 90A
Head Unit: Pioneer DEH-X9500BHS
Front Speakers: Alpine Type S
Rear Speakers: JBL GTO 628's
Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g
Volt Meter: SMD VM-1
Amps: Rockford Fosgate T400-2, T1000-1bdCP
Subs: 2 SSA XCON 15's Sealed
Tint: Privacy glass + 5% in the back and 25% in fronts
Your car doesn't support double DIN HUs? It could get tricky if you have to relocate buttons or climate control stuff. But other than that, if you have the right tools and equipment then it's do-able. Just takes some thought beforehand of how you plan on making everything work right.
Thank you everyone. Can't wait to start the install! As soon as all this snow clears I'm going to go to work on this car. Already have the wires for the big three from previous install. I plan on upgrading the stock radio system with a single din unit, hopefully this wont disrupt my climate controls and from what I read I will only loose voice for the navi unit and voice commands for the car (dont like to use either any way). Anyone know how to retain the steering wheel controls? The battery was ordered and on its way.
As soon as I get back home, and figure out how to add pictures, I will start a build log and show everyone what my plans are.
Thanks again!
  • Who's Online   1 Member, 1 Anonymous, 586 Guests (See full list)
