tcullen1 Posted April 9, 2013 Report Share Posted April 9, 2013 Here are dimensions i can work with (max) 49w x 44d x 25h. Need tuning to be 32hz. Any help would be greatly appreciated. This box will be going in a Tahoe. Thanks 200amp HO Big 3 Diamond Audio S500s (front) Diamond Audio M65.1a (rear) Kenwood KIV-BT901 Kicker, Stinger, Knu 0 gauge, 4 gauge Kinetik HC2000b x 2 Hifonics BE2100.1 Memphis MR4.480 SQ HDC312's x 2 36hz Link to comment Share on other sites More sharing options...
tcullen1 Posted April 9, 2013 Author Report Share Posted April 9, 2013 Actually will use dimensions of 48 with since easier to just cut down middle of mdf. These will be facing up. 200amp HO Big 3 Diamond Audio S500s (front) Diamond Audio M65.1a (rear) Kenwood KIV-BT901 Kicker, Stinger, Knu 0 gauge, 4 gauge Kinetik HC2000b x 2 Hifonics BE2100.1 Memphis MR4.480 SQ HDC312's x 2 36hz Link to comment Share on other sites More sharing options...
tcullen1 Posted April 9, 2013 Author Report Share Posted April 9, 2013 anybody??? 48x44x25.5 seems easier to cut sections but need help with port location n dimensions to get to 32hz. Would like port at bottom of box just dont know how wide or depth??? 200amp HO Big 3 Diamond Audio S500s (front) Diamond Audio M65.1a (rear) Kenwood KIV-BT901 Kicker, Stinger, Knu 0 gauge, 4 gauge Kinetik HC2000b x 2 Hifonics BE2100.1 Memphis MR4.480 SQ HDC312's x 2 36hz Link to comment Share on other sites More sharing options...
Joe X Posted April 9, 2013 Report Share Posted April 9, 2013 So here is a suggestion: Enclosure Specifications:Fb = 32 HzVb = 14 ft^3External Height = 20 inExternal Width = 48 inExternal Depth = 36 inPort Width = 38 inPort Height = 4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 48 x 36Left & Right Sides = 34 1/2 x 17 3/4Front & Back = 48 x 17 3/4L Port Internal Assembly Parts:Front to Back = 15 1/2 x 39 1/2Port Left Side Assembly:15 1/2 x 4Port Right Side Assembly:15 1/2 x 4 Assembly guide (generic dimensions): Important notes:- The port needs 4" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Bracing is a 4"x14" MDF piece in the center of the port and a top to bottom 1 1/4" wooden dowel rod placed directly above the top brace. Link to comment Share on other sites More sharing options...
tcullen1 Posted April 9, 2013 Author Report Share Posted April 9, 2013 Joe, thank you! That looks great. 200amp HO Big 3 Diamond Audio S500s (front) Diamond Audio M65.1a (rear) Kenwood KIV-BT901 Kicker, Stinger, Knu 0 gauge, 4 gauge Kinetik HC2000b x 2 Hifonics BE2100.1 Memphis MR4.480 SQ HDC312's x 2 36hz Link to comment Share on other sites More sharing options...
Joe X Posted April 9, 2013 Report Share Posted April 9, 2013 Happy building! I will update the pic later to show the port and top to bottom braces that can't be seen in the above. Link to comment Share on other sites More sharing options...
tcullen1 Posted April 9, 2013 Author Report Share Posted April 9, 2013 Great look forward to it, starting it tonight! 200amp HO Big 3 Diamond Audio S500s (front) Diamond Audio M65.1a (rear) Kenwood KIV-BT901 Kicker, Stinger, Knu 0 gauge, 4 gauge Kinetik HC2000b x 2 Hifonics BE2100.1 Memphis MR4.480 SQ HDC312's x 2 36hz Link to comment Share on other sites More sharing options...
tcullen1 Posted April 10, 2013 Author Report Share Posted April 10, 2013 Thanks Joe! 200amp HO Big 3 Diamond Audio S500s (front) Diamond Audio M65.1a (rear) Kenwood KIV-BT901 Kicker, Stinger, Knu 0 gauge, 4 gauge Kinetik HC2000b x 2 Hifonics BE2100.1 Memphis MR4.480 SQ HDC312's x 2 36hz Link to comment Share on other sites More sharing options...
