Cboeger Posted April 11, 2013 Report Posted April 11, 2013 Anytime I turn on my heat/AC/Defroster, whatever it is for heat, you name it i get a rough vibration coming from my engine bay to the point where it feels like my car is going to stall out, do you think its a bad IACV(Idle Air Control Valve)?
Rockford96 Posted April 11, 2013 Report Posted April 11, 2013 Anytime I turn on my heat/AC/Defroster, whatever it is for heat, you name it i get a rough vibration coming from my engine bay to the point where it feels like my car is going to stall out, do you think its a bad IACV(Idle Air Control Valve)? i literally had the same problem till yesterday not sire on the iacv but i replaced cap rotor coil plugs wires and it hasnt done it since not sure what car you have but mines a lil older and i think just the strain of the ac alt belt fan makes it rough in my truck cuz when i turn ac off it stopps but good luck! My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Cboeger Posted April 11, 2013 Author Report Posted April 11, 2013 Anytime I turn on my heat/AC/Defroster, whatever it is for heat, you name it i get a rough vibration coming from my engine bay to the point where it feels like my car is going to stall out, do you think its a bad IACV(Idle Air Control Valve)?i literally had the same problem till yesterday not sire on the iacv but i replaced cap rotor coil plugs wires and it hasnt done it since not sure what car you have but mines a lil older and i think just the strain of the ac alt belt fan makes it rough in my truck cuz when i turn ac off it stopps but good luck! 2003 ford focus se sedan and it only does it when i turn ac/heat/defroster on, as soon as i turn it off it goes away
Rockford96 Posted April 11, 2013 Report Posted April 11, 2013 Anytime I turn on my heat/AC/Defroster, whatever it is for heat, you name it i get a rough vibration coming from my engine bay to the point where it feels like my car is going to stall out, do you think its a bad IACV(Idle Air Control Valve)?i literally had the same problem till yesterday not sire on the iacv but i replaced cap rotor coil plugs wires and it hasnt done it since not sure what car you have but mines a lil older and i think just the strain of the ac alt belt fan makes it rough in my truck cuz when i turn ac off it stopps but good luck!2003 ford focus se sedan and it only does it when i turn ac/heat/defroster on, as soon as i turn it off it goes away i had the same problem but it would only do it in park im not sure man sorry My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Nico Shull Posted April 14, 2013 Report Posted April 14, 2013 On the Ford Focus, a VERY common issue is the bottom motor mount on the back of the motor can get rocks stuck in and around it, and up in Canada, Ice often builds up around it. What this causes is the motor vibrations not to be dampened properly by the motor mount. So any time an excessive vibration from the engine happens, due to the electrical load of the alternator sometimes, or going into gear at lower RPM, it CAN cause the car to vibrate intensely. There could definitely be other issues, but I know that motor mount is an extremely common issue! 2004 Ford Freestar SEL Jensen VM9224BT Alpine MRP-F257 "Flex 5" MBQuart ONX 1000.1D Factory Ford 5x7's (For now) 2 - MBQuart ONX304 12" Subwoofers
Cboeger Posted April 20, 2013 Author Report Posted April 20, 2013 On the Ford Focus, a VERY common issue is the bottom motor mount on the back of the motor can get rocks stuck in and around it, and up in Canada, Ice often builds up around it. What this causes is the motor vibrations not to be dampened properly by the motor mount. So any time an excessive vibration from the engine happens, due to the electrical load of the alternator sometimes, or going into gear at lower RPM, it CAN cause the car to vibrate intensely. There could definitely be other issues, but I know that motor mount is an extremely common issue! On the Ford Focus, a VERY common issue is the bottom motor mount on the back of the motor can get rocks stuck in and around it, and up in Canada, Ice often builds up around it. What this causes is the motor vibrations not to be dampened properly by the motor mount. So any time an excessive vibration from the engine happens, due to the electrical load of the alternator sometimes, or going into gear at lower RPM, it CAN cause the car to vibrate intensely. There could definitely be other issues, but I know that motor mount is an extremely common issue! Yeah you gotta install a guard shield or whatever they call it, I'm starting to lean more towards the throttle body/idle air control valve now
sprkn_ranger Posted April 20, 2013 Report Posted April 20, 2013 How much do the rpms drop? Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
Pioneerchuck Posted April 20, 2013 Report Posted April 20, 2013 It sounds like a vacuum problem. Id check to make sure the IACV is operating properly then turn my attention to the rest of the vacuum system. Very very slim chance its the actual throttle body.
CHEVY4X4BLAZER Posted April 20, 2013 Report Posted April 20, 2013 Give it a tune up.my brotha. I had an acceleration problem that was caused by bad, split open spark plug wires. I originally thought it was a fuel pump problem.
Cboeger Posted April 20, 2013 Author Report Posted April 20, 2013 Give it a tune up.my brotha. I had an acceleration problem that was caused by bad, split open spark plug wires. I originally thought it was a fuel pump problem. Yeah I may try that, I'm going to put water on the spark plugs tonight to see if any sparks or whatever show, then I'll replace spark plug wires, coil boot, and spark plugs if it does, since its easy as shit to do on my car lol
