BassMunky Posted April 11, 2013 Report Posted April 11, 2013 there this weird noise coming from my speakers it only happened recently. It like a crackle pop noise when music plays. The highs are ok. rainbow 6.5 germaniums to a sundown 100.4 active. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted April 13, 2013 Author Report Posted April 13, 2013 bump it sounds like lil distortiion like how when you listen to the radio it has lil distortion. something like this, but it not as bad it very faint? what could cause this? thanks http://www.youtube.com/watch?v=bZ2kT4jV19k Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
thefourth Posted April 13, 2013 Report Posted April 13, 2013 Sounds like it's on it's way out.. or a bad set of RCA. Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
shogen Posted April 13, 2013 Report Posted April 13, 2013 if your rainbows sound like that... you're fcked .... lol bump it sounds like lil distortiion like how when you listen to the radio it has lil distortion. something like this, but it not as bad it very faint? what could cause this? thanks http://www.youtube.com/watch?v=bZ2kT4jV19k but I has no real input.... maybe your gain is too high? Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
BassMunky Posted April 13, 2013 Author Report Posted April 13, 2013 it not as bad as the vid. in order to hear that noise you have to put your ear right next to the speaker. even at high levels. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted April 13, 2013 Author Report Posted April 13, 2013 if your rainbows sound like that... you're fcked .... lol bump it sounds like lil distortiion like how when you listen to the radio it has lil distortion. something like this, but it not as bad it very faint? what could cause this? thanks http://www.youtube.com/watch?v=bZ2kT4jV19k but I has no real input.... maybe your gain is too high? what you mean what other info do you need? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted April 15, 2013 Author Report Posted April 15, 2013 bumper Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted April 15, 2013 Author Report Posted April 15, 2013 what would cause a ground loop Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
ric006 Posted April 15, 2013 Report Posted April 15, 2013 had this problem before mine was the glue came off from the cone and when it went out the cone would stay but the could would still be moving
