rockFord_Expedition Posted April 12, 2013 Report Posted April 12, 2013 Amp is warm but not hot! Volt meter is on cig lighter! Amp is seeing 2 ohms maybe more after box rise Well, there's one problem. Use a DMM and measure it at the amp. Do this at idle, and at cruising RPM's. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Pauly1987 Posted April 12, 2013 Author Report Posted April 12, 2013 Am I placing the ddm on the power and ground terminals from the amp? Can I just strip the wires on the current volt meter and plug them in that way I don't have to carry a ddm around everywhere?
rockFord_Expedition Posted April 12, 2013 Report Posted April 12, 2013 Chances are that your cigarette lighter volt meter isn't as reliable as a real DMM. You shouldn't need to carry it with you all the time, just use it at home for troubleshooting this problem. Edit: yes, check it at the amp terminals. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
deathcards Posted April 12, 2013 Report Posted April 12, 2013 Am I placing the ddm on the power and ground terminals from the amp? Can I just strip the wires on the current volt meter and plug them in that way I don't have to carry a ddm around everywhere? there is a reason funky said at idle and at cruising rpms you can do it yourself at idle basically put it on the screws make sure not to ground it to the case cruising has higher rpms = more amps from alternator so rev eninge to around 1500 i would say idle lower rpms less amps from alt best time to do this is when the engine is warmed up cause then the alt is not and not as efficient at keep the voltage at 14.4v skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Pauly1987 Posted April 12, 2013 Author Report Posted April 12, 2013 Alright will do! Thanks for your help everyone! Paul
rockFord_Expedition Posted April 12, 2013 Report Posted April 12, 2013 Report back with your findings Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
deathcards Posted April 12, 2013 Report Posted April 12, 2013 btw what brand alt do you have 150 amps is a lil higher than most oem skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
SnowDrifter Posted April 12, 2013 Report Posted April 12, 2013 I had a friend read his voltage from somewhere in the front of the car. I don't remember where it was.Long story short his amp was playing quiet/shutting off even though his voltage *looked* good. Well come to find out he had a bad connection giving him some serious front-to-back voltage drop. So the amp was playing off the rear battery and was going into low voltage protect. All that to say: you might have a similar issue ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Crandis16 Posted April 12, 2013 Report Posted April 12, 2013 is it just one song? My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
