question about gain setting and hu volt output
DylanBunch
So say you have a hu that has a 2 volt output and you set ur gains a little past half at 2 volts. Then you guy a crossover or eq or something that boost the output to like 7 volts and you have to turn your gain down to where 7 volts is. Is the bass going to be as loud down at 7 volts compared to the gain up at 2 volts before? If you dont understand my question ill try and explain it better
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
it may sound louder cause it is cleaner due to the higher voltage but it shouldn't make a difference unless the amp can't handle 7 volts
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
Not louder, if anything less noise in the system. If everything is working and setup correctly, there will only be a minimal difference in how it sounds, if you can even notice it at all.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
So if you go from a car no clipping at 2v to a car no clipping at 7v youd barely hear a difference? Seems like since the gain is significantly lower itd be quiet lol
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 502 Guests (See full list)
