Kyblack76 Posted June 12, 2013 Report Posted June 12, 2013 ok its a really simple answer, if you are pulling more than 250 or 300a you need to add another run. 250a is cca 300a is ofc... calculate the amout of current your amp pulls and you know how many runs of wire you need and what size wire you need... LENGTH matters also... not just pull, or give. That said.. Im waiting for Tony C to ask why a dude with a 140 amp alt does 44 runs front to rear... You are correct,.. you only need, what you have to give... Other that that, your pissing in the wind... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted June 12, 2013 Report Posted June 12, 2013 Bro, when it doubt? Whip the 1/0 out! This! Id rather buy another amp... or more speakers.. or another battery.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
will77530 Posted June 12, 2013 Report Posted June 12, 2013 ok its a really simple answer, if you are pulling more than 250 or 300a you need to add another run. 250a is cca 300a is ofc... calculate the amout of current your amp pulls and you know how many runs of wire you need and what size wire you need... LENGTH matters also... not just pull, or give. That said.. Im waiting for Tony C to ask why a dude with a 140 amp alt does 44 runs front to rear... You are correct,.. you only need, what you have to give... Other that that, your pissing in the wind... i may be wrong but i believe the amperage rating of the wire is done at 50ft.....i hope i said that right lol im a little tired
Kyblack76 Posted June 12, 2013 Report Posted June 12, 2013 ok its a really simple answer, if you are pulling more than 250 or 300a you need to add another run. 250a is cca 300a is ofc... calculate the amout of current your amp pulls and you know how many runs of wire you need and what size wire you need... LENGTH matters also... not just pull, or give. That said.. Im waiting for Tony C to ask why a dude with a 140 amp alt does 44 runs front to rear... You are correct,.. you only need, what you have to give... Other that that, your pissing in the wind... i may be wrong but i believe the amperage rating of the wire is done at 50ft.....i hope i said that right lol im a little tired What wire? your wire? cuz my wire isnt that good.... or.. is it..?? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
will77530 Posted June 12, 2013 Report Posted June 12, 2013 i think thats for all awg wire, tried googling it to see if i was right and i didnt know how to phrase it so could be wrong
