In what scenarios do you do multiple runs of 1/0
I've heard people recomend multiple runs of 1/0 and I want to know is it recommended for my application.
240a singer alt
1duralastplat upfront
3kinetik 1400s n rear
Amps dd m2b at.5 and jl hd600.4
Also could some explain the benefit of the extra run
Team CNGraphix
2013 sonata
Dc power 320 alt
3 kinetik 3 shuriken
All knue and sky high wiring
Dd m3b x2
Rockford 1000-4
2 fi sp4 18
4 vo 6.5
4 nendo pwx8
6soundqubed tweets
2 b1 tweets
Pioneer avh4500 hu
Depends on the application.
You running OFC or CCA? How long are the runs?
both distance and heat will add resistance to your circuit. Multiple run will mitigate the issue.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I just installed second run. My story is I received some 0 gauge Q power Super Flex OFC for free and wired my truck with XS power d375 in back and Interstate up front. I was running a Arc Audio 600.1 and 80.4. I upgraded to a Arc Audio 2000.1 test sheet on the amp states 2347 rms at 1 ohm. For me I always like to over wire. I went with a second run and upgraded my front battery to a XS power d3400. So far seem to be sufficient.
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
When the current exceeds a single run of whatever wire you're using. There are other factors to consider as well such as metal, size, and length.
  • 1 month later...
good thread
last build was my malibu walled on a single skar 4500 @.33 daily
6 deka g31 batts Singer 330a alt 4 runs of 3/0 front-back
Three hdc3 15
Did a 154.6 this summer at Grassroots
Building a 99 yukon denali atm
18 from canada ontario
ok its a really simple answer, if you are pulling more than 250 or 300a you need to add another run. 250a is cca 300a is ofc... calculate the amout of current your amp pulls and you know how many runs of wire you need and what size wire you need...
  • Who's Online   0 Members, 0 Anonymous, 1649 Guests (See full list)
