i used -10db with my AQ1200 to my pair of sundown sa's i have upgraded that to a AQ2200 so should i still use -10db or -5? iv heard that -10db is just more power then -5 since that is for sq. i just get confused when it comes to this stuff
-5 to be safe
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Ok thanks!!! I'm running 4awg from rear battery to amp, and its only 120amps max so I know the amp should put out more power when I upgrade that to 1/0awg
-5 or if you really want to be an over-achiever, use -0. But then I don't think you'd ever get full power out of the amp unless you are burping
I would use the -5, That's the one I usually use. 0db I use when running .5ohm's to be safe.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
