LordArcane Posted April 13, 2013 Report Share Posted April 13, 2013 As stated this will help you or should help you find out what type of RCA inputs and outputs your head unit and amp uses. sorry for the poor video, as i don't have a very good camera. Part 1: Head Units http://www.youtube.com/watch?v=q59EFRLZd_c Part 2: Amps http://www.youtube.com/watch?v=rhXCwD9hNDo Hope everyone enjoys this little how to video. also some other info you might need to know SE=Coax, Diff=Twisted Link to D'Amore Engineering's video "Truth about RCA signal cables" Link to comment Share on other sites More sharing options...
HunterJohnson Posted April 13, 2013 Report Share Posted April 13, 2013 Sorry to keep asking questions. Anyways so even with the amp disconnected. If you touch ground to RCA outside ground it will give u the same results? Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
LordArcane Posted April 13, 2013 Author Report Share Posted April 13, 2013 yes its should, you will also be able to do this with everything out of car. you would just be assuming your car have great ground throughout. given if you have good ground at your amp/ head unit you can use the grounds from them ( i.e. instead of me using the chassis ground i could have grounded my - lead to the neg power input on the amp and proceed with touch the outer rings. Link to comment Share on other sites More sharing options...
LordArcane Posted April 14, 2013 Author Report Share Posted April 14, 2013 wow, figured with all the talk about this lately it would see more interest, guess i was wrong. oh well Link to comment Share on other sites More sharing options...
ric006 Posted April 14, 2013 Report Share Posted April 14, 2013 haha Link to comment Share on other sites More sharing options...
LordArcane Posted April 14, 2013 Author Report Share Posted April 14, 2013 haha must have missed where there was a joke posted in here Link to comment Share on other sites More sharing options...
scooter99 Posted April 14, 2013 Report Share Posted April 14, 2013 Thanks for the video's. You mentioned another video in video 2 here. Where is that at, if you could link it please. I'd like to see it as well. Thanks! Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
LordArcane Posted April 14, 2013 Author Report Share Posted April 14, 2013 Thanks for the video's. You mentioned another video in video 2 here. Where is that at, if you could link it please. I'd like to see it as well. Thanks! was just the first video, when i had did the head unit, was just using it as example seeing as i got single input coming from deck and diff input going into amps everything you should need info wise, should be in the first post. Link to comment Share on other sites More sharing options...
ric006 Posted April 14, 2013 Report Share Posted April 14, 2013 What i think is so funny no matter what the amps required the ground signal on the shielded end it does not matter if its coax or twisted if you want real coax instead of half coax you can always use some Home R6 cable that u use on your tv and put this connector on it if you want real coax http://www.amatteroffax.com/itempagey_invid_847201_d_cables-to-go-video-adpt-bnc-female-to-rca-male.html Unitil then Yes i work on amps thats why i HAHAH Link to comment Share on other sites More sharing options...
ric006 Posted April 14, 2013 Report Share Posted April 14, 2013 buy yourself a 100 dollar wire and a 10 dollar wire cut them open to find out you have the same wires in side nothing different but the shielding for noise signal Link to comment Share on other sites More sharing options...
