PROBLEM EQ MAYBE HELP ~!?
isolator is a band aid also, but normally works. I always try grounding the radio, eq, and amps together when running an EQ.
SMD SuperSeller VerifiedJbondoXJames Shields
get rid of the EQ ... probably better off without it
My hu only has has 2 outputs what else would you suggest
Are you using your EQ for multiple RCA outputs instead of having an equalizer for sound ???
Both
Forget the EQ and use Y splitters. If your deck doesn't have an EQ I'd be surprised, it may not be as powerful but should get the job done. The less components in your signal path the better.
I'm gonna hate
My guess would be that your problem is in your headunit and it's being amplified by the EQ ...
My suggestion would be to get rid of the headunit and EQ and find you a Headunit capable of working to your application ...
  • Who's Online   0 Members, 0 Anonymous, 1129 Guests (See full list)
