01 S-10 Posted April 14, 2013 Report Posted April 14, 2013 I have Mb Quart components rated at 170 rms per side and was considering running them active. My amp is 100x4 and I'm only running 100 watts to each side, but if I run active each mid and tweet will see quite a bit more power. Anyone think there will be problems or can they handle it? I'm actually worried more about the tweeters TDH FTW !!!
Mtgrooves Posted April 14, 2013 Report Posted April 14, 2013 does your amp have a banpass setting? The Shoe Maker without shoes!
bcbrassard Posted April 14, 2013 Report Posted April 14, 2013 What are your Tweeters rated at? Thats what would worry me. you might have to low the gains or -dbs to keep from over powering them. They will shine going active though. I am pushing my T265 comps with a T400-4 at 75 RMS and they sound way better than bi-amped on the same power.
01 S-10 Posted April 14, 2013 Author Report Posted April 14, 2013 does your amp have a banpass setting? Yes it has bandpass, it's a Cadence zrs C9 TDH FTW !!!
01 S-10 Posted April 14, 2013 Author Report Posted April 14, 2013 What are your Tweeters rated at? Thats what would worry me. you might have to low the gains or -dbs to keep from over powering them. They will shine going active though. I am pushing my T265 comps with a T400-4 at 75 RMS and they sound way better than bi-amped on the same power. That's the thing, there is no rms rating I can find for the mids and tweets individually, just as a pair TDH FTW !!!
bcbrassard Posted April 14, 2013 Report Posted April 14, 2013 Well i would contact MB quarts on there ratings then before you go active on that amp just to make sure you dont blow the tweeters. Thats a bit of power. RF rates the T2 tweeters at 75 RMS and thats what there getting and its really loud, lowered the db by -5 on HU and turned gains down just a fuzz.
03 Xtreme Fosgate Posted April 14, 2013 Report Posted April 14, 2013 Which set do you have BUILD LOG-http://www.stevemeadedesigns.com/board/topic/179004-03-s10-xtreme-ext-cab-rf-build/ PHOTOBUCKET- http://s1354.beta.photobucket.com/user/03XtremeFosgate/library/truck%20audio%20rebuild
01 S-10 Posted April 14, 2013 Author Report Posted April 14, 2013 Which set do you have Q series, not the new ones but the ones from about 08 or 09 Also I just looked and the tweeters are 6 ohm so that will help cut the power down a bit TDH FTW !!!
reg93f150 Posted April 17, 2013 Report Posted April 17, 2013 Sorry for the noob question... But what exactly is runnin active? Thanks!! ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
Trey_Dog650 Posted April 17, 2013 Report Posted April 17, 2013 Having a speaker on its own amplifier channel 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
