I'm about to order a single sa-8 v.2. I'm not sure which one I should get to go good with my amp the dual 4 ohm or dual 2 ohm. The generic power of the amp says 500 @ 4, 750 @ 2, and 1000 @ 1. However the birth sheet that came with it says 750 @ 4, 975 @ 2, and 1300 at 1. So I was thinking to just be safe and get the dual 2 run it at 4 ohm for a while then I can switch it over to 1 ohm later. As far as other electric I have stock altenator, big 3 (done in 4g), 0g power and ground and then 4g from the distribution block to the amps. I'm thinking about gettting one of the dave the box guys single 8" slot port boxes, .75 after displacement tuned to 35 hz. Its going in a scion tc.
Let me know what you guys think I should do to get a good over all sound and still be able to get loud if need be.
Get two and run 1-ohm FTW.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
4 gauge big 3 and 0 gauge power wire?? Should have used 0 gauge for Big 3 man!
Edited: didnt see that you had 0 gauge into distro blocks
Edited by FosgateLife
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
I had two sa-8 v.1 in my truck. Then I got 2 sa-12 in my tc and they take my whole trunk. So i'm just looking for something to hold me over till the x-8s finally come out. Just want to check which would be the best to use.
4ohm on one sa-8...still almost double rated power.
Vehicles
2005 GMC Canyon
Sold to:
on the 750 @ 4 ohm on the birth sheet was 14.5 volt stable, which I know I'm not at so Its probably closer to 600 something. right? which isnt bad since the subs are 500 rms and I've seen then on 1000 watts before.
I agree, I would save up for another 8 to wire down to 1 ohm.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
If you are looking to save space then yes at least two 8"s, two 10s will give you about 43% of extra cone area and will only cost you about 0.8 cubes of extra of net volume. Depends on your goals.
  • Who's Online   0 Members, 1 Anonymous, 2806 Guests (See full list)
