ENGINE NOISE HELP!!!
hey guys finally got my mids and highs amp hooked up and i started to get engien noise so i thought hey just ground my RCAs on the HU and it will fix the problem but i tried that ive check all grounds and all different kinds of things and ill be damned if the engine noise wont go the hell away i could really use some help any suggestions please comment
any way to try a different HU? then you could at least rule that out.
i have a spare hu but it only has a sub output on it but i tihnk i could probably find one
welcome to my world... Tips i have gotten which helped but didnt fix the issue is: Ground the HU to where your amps ground at, obviosly use quality rca's to see if that helps, run a ground wire around all rca connectors on back of HU and ground that "strap" to the HU itself. Ground chassis of HU to where amps ground at......
I love my staffie :good:
So anti FACEBOOK it isn't even funny
i did that also i even REDID my grounds that i have to my frame took them off ground them down some more to see if that would change anything but it didnt
yuppers, i hear ya... been fighting this issue for a long time... Join my club and lets get the new alpine 149bt HU... should fix us up fer good ;) Ill be nice and let you buy it first and let you tell me if it fixed your problem, then ill buy it
YOUR SOOOO FUNNNY!!!!!!!!!!!!!!!!
