What kind of fuse holder is this?
I blew this fuse holder a while back, i've been slacking on getting a new one. Wondering what kind of fuse I can use to replace this, it was a 70-80 amp fuse running on 500w rms amp, hence why it ended up getting smoked. Should I get a new fuse, or go with a stinger fuse holder w/200 fuse.?
agu, find out why you blew the fuse before you replace it
Used to have a loud truck
something isn't right you blew it on 500 watts check your wire for cuts, abrasion, and make sure it isn't grounding out
what kind of amp
200 amps!!! are you kidding me your alt don't make that much
sorry didn't mean to freak out
he has a mrp-500 guessing at 2 ohms
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
what kind of amp
Alpine mrp-m500, it's the only fuse that my local store has in stock :( and all of my wires and such are perfectly fine.
get another 70 amp fuse are you experiencing any voltage drop (lower volts means more amps), is the amp getting warm, have you checked connections at bat,amp, and ground loose connection are no good and can increase resistance which could be why your fuse blew
skar sk2500.1
alpine HU
2 x-15 sundowns
my ground was slightly loose, and my amp does get pretty warm. And can I use any AGU fuse with this? Just the design of this stock one is different from others.
agu fuse is a agu fuse where is you ground located? and make sure you have the gound sanded to metal not paint/primer, sometimes rust can build up lithium grease will keep that from happening
i am gonna guess you tightened the ground
skar sk2500.1
alpine HU
2 x-15 sundowns
There's like a metal looking cap in my trunk, up towards the bottom right, and what screwed down the cap I placed in my ground(It's a metal/metal surface)
  • Who's Online   0 Members, 0 Anonymous, 515 Guests (See full list)
