tire size question
My taurus has 215/60r16 tires on it and one is looking pretty ragged. I have an extra rim and tire lying around with the same bolt pattern. But the extra is a 205/65r15. They look to be pretty close in size but are the safe to switch out? I only need to get to work tonight and the store tomorrow. Thanks for any help
Current System:
Clarion CZ702
Stock 5 channel amplifier
Infinity Reference 4022i 4"
GRS 6.5"
Audiopipe 1800.1
2 RE Audio SEX V2's In a 4th order ported though the armrest
2003 130 Amp Toyota Highlander alternator
yeah that should be okay, make sure the center of the hole (bore of the wheel) is the same or bigger so it sits right when u bolt in on
i would def keep it on the rear, if its on the of the fronts i doubt it will even work on there because of the caliper, but even if it does work on the front put it on the rear so it does affect ur steering
hope that helps
