what should i do? looking to upgrade
I currently have 2 rockford fosgate p2d2 subs hooked up to a kenwood kac9105d amp. I have them in a ported box tuned to about 33hz.
Im looking into upgrading the amp because this one has been nothing but trouble for me. it constantly cuts out on just about everything at random times. it can hold some notes and not others so im just ready to get rid of it. Im thinking of upgrading to a rockford fosgate
t1000
http://www.amazon.com/Rockford-Fosgate-Power-T1000-1BDCP-amplifier/dp/B003AILWGK/ref=sr_1_3?s=car&srs=2530319011&ie=UTF8&qid=1367363121&sr=1-3&keywords=rockford+fosgate
or a
t1500 which is $517 on amazon.
is there any other amps that put out around that kind of power for better prices? or any other recomendations? im on a relatively tight budget but i have some cash to spare. 500 is about the limit.
Thanks for any help
Soundquebed 2200.1 amp. Does more power then it's rated for. I believe is 429.99 plus shipping. Great amp. Just make sure u have the electrical to back up 2-2.5k of power
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
wiring to 2 ohms, that amp should work fine. otherwise he'll fuck the woofers up at half ohm LOL. they're only 400rms a piece.
from what you posted i know why your amp keep shutting down. you have 2 dual 2 ohm subs. i bet they are wired at .5 ohm.. wire them to 2 ohm and you wont have that issue anymore.... not unless you dont have the electrical
if youre running that amp at half ohm im willing to bet you are also clipping it. i have ran the lanzar cheap amps at lower recommended load and didnt have any issues. you need the proper electrical to run the amps more efficiently
i dont have the electrical for that haha. but the 1200 watt amp has got me interested. i have the subs and amp wired to 2 ohms. maybe ill get the 2200 though and upgrade all the electrical over time
You really don't need something as powerful as that 2200 to push those subs. A DC 1.2k, SQ 1200, or something similar would be enough for those subs.
Chevelle%20Team%20Cover%20without%20RE%2
^Vehicle log to come soon for this.^
It's better to shoot for higher end gear as one may need it later... it's just a question of setting up the amp correctly to avoid damaging the subs.
internals of the current kenwood kac 9105 d amp. i even grounded it to the battery of the car and its still cutting out. its properly wired to 2 ohms. i think its just a bad amp.
im still looking into buying a better amp but i havent decided yet.
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
