gattiboy13 Posted May 4, 2013 Report Share Posted May 4, 2013 RF P2D4 10" This is sub I have, I have swapped sub out once becuase of a slapping sound, kinda like the dust cap is being hit. Sounds bad, but only on certain songs or lows. I have swapped amps, wires etc...cant find problem! So last option is box...here is box I have now an RF specs from site. Is my box now way offf and cuasing it to sound shitty? I have the ground shaker box here http://ground-shaker.com/en/catalogo/detalle/126 and here is what RF reccomends http://www.rockfordfosgate.com/products/product_details.aspx?itemid=120414 Please help someone. Link to comment Share on other sites More sharing options...
Hugh G. Rection Posted May 4, 2013 Report Share Posted May 4, 2013 got a subsonic filter on your amp? sounds to me like its playing below the port tuning of that shitty fucking box. Owner of BigAss Ports Link to comment Share on other sites More sharing options...
gattiboy13 Posted May 5, 2013 Author Report Share Posted May 5, 2013 Yes it does. Where should it be? How do i tune it to box? Box i believe is around 40-45 hrz Link to comment Share on other sites More sharing options...
Joshex Posted May 5, 2013 Report Share Posted May 5, 2013 Don't tune it with the box, tune it for the sub. The filter is so you can prevent certain frequencies from playing that are bad for the sub. Edit: What is your subsonic currently at? Try adjusting it until you can't hear the sub "bottoming out" 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here Link to comment Share on other sites More sharing options...
gattiboy13 Posted May 5, 2013 Author Report Share Posted May 5, 2013 I will play with it in a bit. And get back to you guys. Thanks Link to comment Share on other sites More sharing options...
gattiboy13 Posted May 5, 2013 Author Report Share Posted May 5, 2013 Subsonic on my amp is 10-50hrz, i have it all the way down...is that correct? Link to comment Share on other sites More sharing options...
Guest Posted May 5, 2013 Report Share Posted May 5, 2013 you need to have the subsonic a few hertz below box tuning. having it at 10hz is a gigantic no no Link to comment Share on other sites More sharing options...
gattiboy13 Posted May 5, 2013 Author Report Share Posted May 5, 2013 Ok thank you. Gonna tune and see if this works out. Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 5, 2013 Report Share Posted May 5, 2013 you need to have the subsonic a few hertz below box tuning. having it at 10hz is a gigantic no no Having it at 10,.. is having it OFF... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
gattiboy13 Posted May 5, 2013 Author Report Share Posted May 5, 2013 I turned it up to 50hz all the way and slapping is gone! Awesome, thank you guys for advice! Link to comment Share on other sites More sharing options...
