Some help please..3000 watts
alenv10
lol i have pre ordered with them before, turned into a couple of weeks later but atleast that way i can scoop up money for the 3500 and wires..
and anyone know where to get those things u put in your amp and it gives 2 inputs?
like 1 0 gauge input on amp and add another 2
NOTHING DOWN HERE YET :(
OBSIDIAN FTW
Toolmaker. I don't have a link, but you can look him up here in the forums, or on the web I think. Some people say you lose a lot of power by using those, but I see a lot of people still using them, so I don't know... I think that if you have enough juice/draw that you NEED 2 or more runs to effectively get it all there, then you probably will still gain power by using them versus not using them and sticking with 1 run.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
yea i found it, well im going to just get sky high car audio OFC 1/0 and i should be just fine
Does anyone have links to good posts about box rise and how to lower it, keeping the rise low
OBSIDIAN FTW
you will love your 1/0 shca and i personally like my toolmakers for the 1/0 to 4 ga reducers. and i still think that doing dual inputs can only help. and i am no expert about box rise but from what i understand at different frequencies the resistance inside your box raises the ohm load. i even saw a program showing that doing a sweep will actually increase and then decrease your impedence throughout the sweep. how and why it all work idk, but i do know its a factor that has to be accounted for.
2005 ford explorer xlt limited 4x4
2 xs power d3400s
2 runs of shca
mid/ highs- infinity 6x8 3 ways
2 18 ssa icons
2 aq 1200.1 @ 2 ohms
10 cubes tuned to 36 hrz
Audioque/soundqubed or crescendo! Many have said it over and over! You will have a hard time finding other amps that push the same clean quality power for the price. To be honest 3500watts and up is usually in the 1300-2000$ bracket.
No it isn't. More in the 800-950 range.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
The Saz-3500 msrp around $1450 but is about $1100 on Amazon, the DDm3b has an msrp around $1150 so you can probably find it a little cheaper. Might be some better deals floating around out there though if you know where to find them. There is also the Stetsom 3K7 ES (I like that it is rated at 12.6V instead of 14.4) which should be in the $700 I think.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
Hifonics brz2100
Kicker 300.2
Optima Blue Top
Build log
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
