Ram, 2 18's in A STICKERBOMBED 4th! Vids on last page!
How does it sound through back window?
So far it's sounding great. Not as loud as I think it should be, but it could be a number of things. Once I get the proper power then I'll experiment here and there.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
what up art!? what are you doing tomorrow?? me and john are driving up to kevins tomorrow morning if you wanna roll...
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
get itttt
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
update
So the issue now is the box behavior. It's not playing like it should. 2 18's even on only 4k should be louder that what it's at right now.
Most likely what will happen is some tweaks to the box. Shrinking the ported section down to 19 cubes from 23, and shrinking/altering the port. When this will happen, who knows. My job is seasonal, so since I'm not working whatever money I have goes to gas for school.
Changing the front chamber volume will only decrease the gain in the box.
U'd be better off by elaborating on the port area, towards the smaller size.
Rule of thumb says - shoot for about half cone area. If u don't have insane power - go for less. The reason is there is a lack of compression in the front chamber due to too large port.
Good luck :)
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
Just an idea for your accordian boot problem. My solution from when I did mine years ago.
Make a posterboard/cardboard template to match the truck window to the camper shell opening
Cut it out of some 1/8th" aluminum
Drill about 6 holes in it
Paint to protect against rust, use some 3m window sealant and silicone and rivet it into place
It doesn't have to be perfect, just close enough..
Had it like this for three or four years and it never leaked on me
Build is looking good, looking forward to seeing how the port and chamber modifications work out.
Good luck :)
This, don't shrink you ported chamber! Do you know your sealed resonance?
Team NorthWestSPL
I don't know my sealed unfortunately, I didn't think to test that lol. But What I did yesterday was make some small port plugs that cut about 5" off each side of the port. IIRC when I looked it up on torres it brought the port area down to 280 and gave something like 13 per foot for port area, tuned to 44hz. What's a good number to shoot for with a 4th order in terms of port area per foot? Is 13 too little?
Damn this is sick so far!!! Would like to hear this, tuned in!!!
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
