TylerParrish Posted May 9, 2013 Report Posted May 9, 2013 Alright so I threw a system in last night. There's an s3400 up front with 1 1/0 run to a d2700 and xp950 in the back, its grounded in the back (shitty ground) but the spot is sanded down. I can turn it up to about 7 or 8 before it cuts out, I figure it's just the shitty ground, but trying to see what other people think it could be. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
SnowDrifter Posted May 9, 2013 Report Posted May 9, 2013 Try wiring the amp straight to the battery ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SnowDrifter Posted May 9, 2013 Report Posted May 9, 2013 Also: what's your voltage at the amp and can you verify your ohm load with a dmm? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
TylerParrish Posted May 9, 2013 Author Report Posted May 9, 2013 Also: what's your voltage at the amp and can you verify your ohm load with a dmm? Have not yet checked voltage, but the gain is all the way down and its at 4 ohms, so it shouldn't be sucking up all the amps my car has. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
basshead8569 Posted May 9, 2013 Report Posted May 9, 2013 Could be the subs wired wrong or ohm load is lower then what the amp can handle. But, I see this a lot at the shop I work at and it turns out to be subs wired wrong/ohm load to low for amp. Start with checking all the wiring. If you have a meter see what your subs are metering. Could have a bad sub. Good luck. Hope its just something small. Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers.
SnowDrifter Posted May 9, 2013 Report Posted May 9, 2013 Also: have you checked your fuses? No loose strands on the speaker wire that could be shorting out? Tightened all connections to be sure? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
TylerParrish Posted May 9, 2013 Author Report Posted May 9, 2013 Could be the subs wired wrong or ohm load is lower then what the amp can handle. But, I see this a lot at the shop I work at and it turns out to be subs wired wrong/ohm load to low for amp. Start with checking all the wiring. If you have a meter see what your subs are metering. Could have a bad sub. Good luck. Hope its just something small. I'll go check, but all I did was move my sub from one car to my current car. It was wired at 4 ohms before and nobody has messed with it. I'll see what ohms it's at in a minute. Also: have you checked your fuses? No loose strands on the speaker wire that could be shorting out? Tightened all connections to be sure? All the connections are in their correct holes and no wires are touching. I'll go dis and re connect all my wires real quick just to make sure. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TylerParrish Posted May 9, 2013 Author Report Posted May 9, 2013 Could be the subs wired wrong or ohm load is lower then what the amp can handle. But, I see this a lot at the shop I work at and it turns out to be subs wired wrong/ohm load to low for amp. Start with checking all the wiring. If you have a meter see what your subs are metering. Could have a bad sub. Good luck. Hope its just something small. Sub was blown the fuck? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TylerParrish Posted May 9, 2013 Author Report Posted May 9, 2013 Hooked the 9510 up to it (made my steering wheel flex on volume 7....free-air) Which leads me to believe I have my 360 gain turned up too high and the amp can't accept such a high input voltage. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
