Pauly1987 Posted May 10, 2013 Report Posted May 10, 2013 Think this will work? I know this amp is only rated for 2ohm's and some have had luck at 1ohm and some havnt! I guess my question is will I stand a better chance of getting this to work because I'm at 1.33ohm After box rise I may be in the 2ohm range and actually get some true 2500w rms out this thing
2000s-10 Posted May 10, 2013 Report Posted May 10, 2013 No experiance with ths amp...but like you said..after rise you should be fine in my eyes.. 1999 grand prix gt kenwood x994 head unit 1/0 big 3 all shok industry single run to the back New mid/highs coming not sure what Soundqubed q2200d at .5 (have) 2 soundqubed hdc3 12s (have) New box to be built.. sealed firing forward (yet to be designed) 200 amp alt not sure exact size or manufactor xs power batts
MrSkippyJ Posted May 10, 2013 Report Posted May 10, 2013 personally I wouldn't do it, nor would I trust rise to save my amp. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Pauly1987 Posted May 10, 2013 Author Report Posted May 10, 2013 Really? 1.33 after rise I wouldn't be far off from 2ohms and as long as as I keep my amp feed with a healthy voltage I shouldnt fry the thing.... But with that said I'm here to learn, is there any perticular reason why u wouldn't?
Nikitaaa Posted May 10, 2013 Report Posted May 10, 2013 Try it and tell us what happens. Don't let anyone tell you it will or won't work. Just except the consequence if you toast an amp. If you're not accepting of this, I wouldn't try in the first place because it's a possibility. My honest opinion though, I would give it a go. 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
slowfkncar Posted May 15, 2013 Report Posted May 15, 2013 Will shut off on music lol tried it myself,unless you have crazy rise at a wide range of frequencys.
dblovah51 Posted May 16, 2013 Report Posted May 16, 2013 ^^^ he is right ive seem them play on good electrical but the majority has shut off 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
alsa2009 Posted May 16, 2013 Report Posted May 16, 2013 Im like the others....I wouldnt tell you to go for it and then you get the magic smoke. I myself have 2 2008 Kicker Zx1500.1's and I had them playing on 4 Kicker L7 12's 4ohms each wired down to 1 ohm a pair. Never had a problems with them at all. Now Im currrently running different subs in a different enclosure and they still putting out. And thats with top notch electrical. I've even been told by one of the Kicker techs that (MY AMPS) wouldnt have a problem running at 1 ohm.....but you couldnt crank the gains up like a newbie....which I never done. So I'll say this...if it shuts off then your amp might not be capable of playing at that low of a ohm load. HU: Pioneer AVH-X4600BT Front Stage: 6 Kicker KS60's-2 Kicker KS6x8's Back Stage: 6 Kicker KS60's-2 Kicker KS6x9's Blowthru: 6 Pyle Pro audio 8's, 2 Pyle Pro Audio 6.5's, 4 Selenium super tweeters Amps: 2 Kicker ZX1500.1's 2 Kicker ZX850.2's 2 Kicker SX900.2's Subs 4 DC Soundlab Level 4 12's D1's Alt: Mechman 270xp 6G Batterys:Diehard Platinum, 2 Kinetik HC2400's 2 Runs of Stinger HPM 0ga DC Audio build. Middle of page 4... http://www.stevemeadedesigns.com/board/topic/130652-96-crown-vic-system-upgrade-4-dc-audio-lvl-4-12s-more-to-come/page-4 Blowthrough build http://www.stevemeadedesigns.com/board/topic/189217-crown-vic-project-blowthrough/
reddude157 Posted May 18, 2013 Report Posted May 18, 2013 Before you go trying this how is your elec like have you done the big three do you have a good batt I.e. yellow top xs power stinger is you Alt up to par or do you have A h.o. One if your lights dim at all right now when you turn it up I would not do it but if the elec is there give it a shot 2001 e 150 conversion van kenwood kdc u942hd lanzar opti 1900d kicker zx 650.4 2 12" obsidians in a 33 hz box 4 set 6x9 2 8" mid woofers 2 almani tweets 200 amp alt 1750 oddesey front 2150 oddessy back 0 ga wire 8 ga sub wire 138,6 db
