smokinwiz Posted May 20, 2013 Report Share Posted May 20, 2013 Looking to upgrade my blowthrough to 4 zv3 18s not sure how I should design the box anyone have ideas I have 4 ft by 8ft with 22 in tall but my blow5hrough opening is only 15. Link to comment Share on other sites More sharing options...
dolarbilz Posted May 21, 2013 Report Share Posted May 21, 2013 What you mean opening only 15 is that tall or wide? More then likely you going need do a 4th order.. What do you have now for subs? What kind of power you going run? Link to comment Share on other sites More sharing options...
smokinwiz Posted May 28, 2013 Author Report Share Posted May 28, 2013 The cutout in the truck ia only 15 tall not the full 22 so the port must be smaller than the box I currently have 2 aq hdc3 12s on 3k Link to comment Share on other sites More sharing options...
Smoove Posted May 28, 2013 Report Share Posted May 28, 2013 15" high. How wide? And personally I'd cut a bigger hole and do a 6th order for doing 4 18's. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
dolarbilz Posted May 28, 2013 Report Share Posted May 28, 2013 Have you thought about 4 12's with 6k instead then leaves plenty of room for batteries.15" high on cutout is fine just depending on what you want to do..look up blow through on here Audio innovation has truck with 15's Check out sanitarium truck as well he has 18's Link to comment Share on other sites More sharing options...
mrd6 Posted May 28, 2013 Report Share Posted May 28, 2013 How wide can your blow through into the cabin get? This will help determine what kind of enclosure/cone area you can use. You have alot of room to play with though if you are willing to use that whole space My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL Link to comment Share on other sites More sharing options...
