Dlongpine Posted May 20, 2013 Report Posted May 20, 2013 I have a 99 tahoe 4WD with a 350 5.7 a/c and heat I have changed the idler pulley( 3 weeks old) and put a new water pump on (3 weeks old) also the tensioner is a couple months old and the belt is only 2 weeks old. the belt tightness is right stock alternator I do have a sound system in my tahoe 4 12inch kickers and 2 - 1500.1 amps with 0 gage wire But my belt/pulleys are squealing or sqeaking, and as i hit the gas or go faster the louder it gets, but i do not know what is causing it to sqeak? I did use break clearner and a brush to clean every pulley and the belt before putting the belt back on. Belt conditioner makes the squealing louder Does anyone know what could be causing this to squeal or sqeak?
fox_racin4 Posted May 20, 2013 Report Posted May 20, 2013 Alt pully. Or one of the pullys isnt lined up properly 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Trey_Dog650 Posted May 20, 2013 Report Posted May 20, 2013 Or is done and needs to be replaced 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
Ben Fultz Posted May 20, 2013 Report Posted May 20, 2013 First thing you could try is to look across the pullys from side of vehicle ( near fender) as see if any are out of alinement or wobbly. If nothing appears to be out of wack, use wd 40 or pb blaster and spray each pully from behind, one at a time and when squeaking stops thats the one that needs replaced.
fox_racin4 Posted May 20, 2013 Report Posted May 20, 2013 First thing you could try is to look across the pullys from side of vehicle ( near fender) as see if any are out of alinement or wobbly. If nothing appears to be out of wack, use wd 40 or pb blaster and spray each pully from behind, one at a time and when squeaking stops thats the one that needs replaced. Yeah... No Because then theres oil on the belt... Not good. Use soapy water, amd spray on each pully one a a time, Or if your brave enough use a bar of soap on the pully itself 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Ben Fultz Posted May 20, 2013 Report Posted May 20, 2013 First thing you could try is to look across the pullys from side of vehicle ( near fender) as see if any are out of alinement or wobbly. If nothing appears to be out of wack, use wd 40 or pb blaster and spray each pully from behind, one at a time and when squeaking stops thats the one that needs replaced. Yeah... No Because then theres oil on the belt... Not good. Use soapy water, amd spray on each pully one a a time, Or if your brave enough use a bar of soap on the pully itself Should have been more clear I guess, spray back side of pully where bearings are, not on belt, but I'm sure soap would also work.
Dlongpine Posted May 21, 2013 Author Report Posted May 21, 2013 How does the bar of soap work? And which back side of the pulleys do I spray? All of them? I looked from side to side at all the pulleys, the bottom pulley which is the Crank Shaft Pulley/Harmonic Balancer has kind of a wobbly..A Little wobble
SnowDrifter Posted May 21, 2013 Report Posted May 21, 2013 First thing you could try is to look across the pullys from side of vehicle ( near fender) as see if any are out of alinement or wobbly. If nothing appears to be out of wack, use wd 40 or pb blaster and spray each pully from behind, one at a time and when squeaking stops thats the one that needs replaced. Yeah... No Because then theres oil on the belt... Not good. Use soapy water, amd spray on each pully one a a time, Or if your brave enough use a bar of soap on the pully itself Should have been more clear I guess, spray back side of pully where bearings are, not on belt, but I'm sure soap would also work. Still no. A pulley needs friction to work. Squealing is caused by the demand of whatever it's driving exceeding the amount of friction the belt/pulley have. Spraying protective oil on the bearings won't do anything and will just get overspray on your belt. Making the slipping issue worse (even if it becomes silent) Does it squeal all the time? Only when you turn the wheel? High electrical load? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
ric006 Posted May 21, 2013 Report Posted May 21, 2013 put a dry bar of soap on your belt grooves while running for like 5 seconds if still making noise then you have a pully problem and could be the tensioner
Dlongpine Posted May 21, 2013 Author Report Posted May 21, 2013 It spueals at the time. from the start of the truck which is a low spueal sometimes none at aloo, but then as soon as i start driving and hit the gas the spueal becomes worse(louder)
