need help with designing a box
ive got a 95 blazer, i wanna build a box for 2 12 inch dc level 4's ill be getting sometime soon. this is the first time of trying to build a box and was wondering how to go about doing this and if someone could help me or show me how to use the torres calculator to build a box. i would like it to have the port facing the back and the subs firing up and idk what size the port needs to be for tuning purposes but i can find the dimensions of the back of my blazer tomorrow if someone is willing to help me just do a basic design. ive got a t2500.1bd and was just wondering on the space ill need and the port size for tuning. thanks a lot if you can help me :)
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
4 polk audio door speakers
2 dash speakers(coming soon)
1 amp to run my mids and highs(coming soon)
The dimensions below have worked for similar Blazers, just check you can fit the following (2x DC Audio L4m2 subs up/port back):
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 3.75 ft^3
External Height = 16.25 in
External Width = 38 in
External Depth = 20 in
Port Width = 4 5/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 38 x 20
Left & Right Sides = 18 1/2 x 14
2x Front = 16 11/16 x 14
Back = 38 x 14
Shared Port Internal Assembly Parts:
2 x Front to Back = 16 3/16 x 14
2 x Extension = 9 15/16 x 14
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 4 5/8" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Thanks a lot I really appreciate it :)
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
Does adding the 45s make much of a difference or is it kind of a preference thing?
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
It's a controversial topic, at least the 45s at the turn of the port are recommended and all sharp edges inside the port should be rounded or slanted.
Ok :) so is there anything special I need to do to put the 45s in the port area?
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
just rendered it using joes specs. ive got nothing better to do lol
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Hey joe the diagram shows 2 sides on the left but not on the right, is there only supposed to be one sheet on each side?
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
  • Who's Online   0 Members, 0 Anonymous, 1005 Guests (See full list)
