STEvil Posted September 18, 2013 Report Posted September 18, 2013 You can cut the aluminum with the circular saw depending on the blade. If the carbide tips are small you're ok. If they stick out like a wood cutting blade you're going to kill yourself. As long as you have the shims in with the aluminum rods you should be ok. You could use turnbuckles inside to allow slowly letting the top plate down, though the amount of pull force its going to have may just strip the threads.. this thing is going to be retarded to get down softly. If you built some shims you could use external turnbuckles that are larger that attach outside the motor and use the shims to stick into the motor. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Junior Russell Posted September 19, 2013 Report Posted September 19, 2013 Why not pick up a threaded rod or two from home depot make the into studs drill some holes in the plate where the outer poles are tap said holes and "unscrew" the plate down onto the poles? Sorry I'm sure you have your way of doing it, you couldve even been talking bout something like that idk just saying an easy way that makes sense in my mind carry on good sir http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
Dwn4BassAlan Posted September 20, 2013 Author Report Posted September 20, 2013 knock that gap down to 1/4" I say. If I did, getting the aluminum pieces out would be next to impossible without damaging the plate surface, and I'm going to seal it to prevent anymore rust so I want to leave it unscratched if possible. It might also be close enough to move the magnet poles around and throw off alignment. Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620 Fucking love Alan you goddamned fucking super nerd lol When Alan uses big words I don't understand It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room. I missed Alan. RIP 5/29/15 - I love you son.
Dwn4BassAlan Posted September 20, 2013 Author Report Posted September 20, 2013 You can cut the aluminum with the circular saw depending on the blade. If the carbide tips are small you're ok. If they stick out like a wood cutting blade you're going to kill yourself. As long as you have the shims in with the aluminum rods you should be ok. You could use turnbuckles inside to allow slowly letting the top plate down, though the amount of pull force its going to have may just strip the threads.. this thing is going to be retarded to get down softly. If you built some shims you could use external turnbuckles that are larger that attach outside the motor and use the shims to stick into the motor. Sorry I'm not quite sure what you meant about the turnbuckles? Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620 Fucking love Alan you goddamned fucking super nerd lol When Alan uses big words I don't understand It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room. I missed Alan. RIP 5/29/15 - I love you son.
Dwn4BassAlan Posted September 20, 2013 Author Report Posted September 20, 2013 Why not pick up a threaded rod or two from home depot make the into studs drill some holes in the plate where the outer poles are tap said holes and "unscrew" the plate down onto the poles? Sorry I'm sure you have your way of doing it, you couldve even been talking bout something like that idk just saying an easy way that makes sense in my mind carry on good sir How am I going to drill into the plate? It's magnetized, and the drill bit would walk everywhere unless it was stainless, but then it would be too soft to drill the steel, then the tap would get stuck to the poles too. I wasn't sure what you were trying to say about unscrewing the plate though? Do you mean feed the rods through the top plate and the bottom plate? Where would the bolt-nut go? Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620 Fucking love Alan you goddamned fucking super nerd lol When Alan uses big words I don't understand It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room. I missed Alan. RIP 5/29/15 - I love you son.
STEvil Posted September 20, 2013 Report Posted September 20, 2013 Why not pick up a threaded rod or two from home depot make the into studs drill some holes in the plate where the outer poles are tap said holes and "unscrew" the plate down onto the poles? Sorry I'm sure you have your way of doing it, you couldve even been talking bout something like that idk just saying an easy way that makes sense in my mind carry on good sir How am I going to drill into the plate? It's magnetized, and the drill bit would walk everywhere unless it was stainless, but then it would be too soft to drill the steel, then the tap would get stuck to the poles too. I wasn't sure what you were trying to say about unscrewing the plate though? Do you mean feed the rods through the top plate and the bottom plate? Where would the bolt-nut go? You drill it with a drill bit. Probably a tungsten one.. well, several. Last time I did stainless it took me about 15 of them. You use a center-punch to mark the start point so the bit doesnt walk. Tap would get stuck to what? Its a tap, it makes threads, its not going to get stuck anywhere unless you use it incorrectly. You thread the rod through the plate and put it in the center of the neo's then turn the rod to slowly lower the plate onto them. No need for a nut really, but you could put one on the end of the rod thats not against the neo's to allow easier turning of the rod. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Chris Hammer Posted September 20, 2013 Report Posted September 20, 2013 Purple did that with his solox build...tapped and used bolts to drop the top plate softly onto the slugs. Still had to line up his pole piece exactly and on one of the mos powerful ferrite mags around. No reason you couldn't use long bolts the same as the threaded rod...probably only need three or four nice high grade hardware. MY BUILD *****http://tinyurl.com/gmcbuild***** Vehicles 2005 GMC Canyon CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.) crf250r - Used to be race bike..now I just trail ride..practice at the track on it. CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg Sold to: Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585 Shower farts still piss me off.I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
Junior Russell Posted September 20, 2013 Report Posted September 20, 2013 What stevil said thanks for putting it in a way that's easier to understand dude http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
Dwn4BassAlan Posted September 20, 2013 Author Report Posted September 20, 2013 Why not pick up a threaded rod or two from home depot make the into studs drill some holes in the plate where the outer poles are tap said holes and "unscrew" the plate down onto the poles? Sorry I'm sure you have your way of doing it, you couldve even been talking bout something like that idk just saying an easy way that makes sense in my mind carry on good sir How am I going to drill into the plate? It's magnetized, and the drill bit would walk everywhere unless it was stainless, but then it would be too soft to drill the steel, then the tap would get stuck to the poles too. I wasn't sure what you were trying to say about unscrewing the plate though? Do you mean feed the rods through the top plate and the bottom plate? Where would the bolt-nut go? You drill it with a drill bit. Probably a tungsten one.. well, several. Last time I did stainless it took me about 15 of them. You use a center-punch to mark the start point so the bit doesnt walk. Tap would get stuck to what? Its a tap, it makes threads, its not going to get stuck anywhere unless you use it incorrectly. You thread the rod through the plate and put it in the center of the neo's then turn the rod to slowly lower the plate onto them. No need for a nut really, but you could put one on the end of the rod thats not against the neo's to allow easier turning of the rod. I'm still a little confused, and the tap would get stuck to the magnetized plate I'm saying. I CAN'T DRILL OR USE ANYTHING MAGNETIC NEAR THE BOTTOM PLATE, just so that is crystal clear to everybody. Sorry I have had terrible insomnia for the last 4 days, haven't seen more than about 9 hours of sleep combined. Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620 Fucking love Alan you goddamned fucking super nerd lol When Alan uses big words I don't understand It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room. I missed Alan. RIP 5/29/15 - I love you son.
Chris Hammer Posted September 20, 2013 Report Posted September 20, 2013 You DON'T touch the bottom plate with any type of tap or drill or anything.. Look in purples thread about getting his top plate off the solox and back on without demag... You would just need longer bolts. No threading the bottom plate, only the top plate. You could even us the current holes for the basket and make them tapped through the top plate. MY BUILD *****http://tinyurl.com/gmcbuild***** Vehicles 2005 GMC Canyon CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.) crf250r - Used to be race bike..now I just trail ride..practice at the track on it. CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg Sold to: Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585 Shower farts still piss me off.I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
