Homemade Super-Neo Woofer: THE CHEVELLE RESTORATION IS DONE, dampener recommendations??
On a positive note. I think. Now that you have the motor built, it's just trial and recone correct?
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
I'm trying to avoid $100 recones after each test though, so lets call it, "Extremely careful and safety trials, and if absolutely necessary, a recone or 2." :D
Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King
Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620
Fucking love Alan you goddamned fucking super nerd lol
When Alan uses big words I don't understand
It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out.
Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room.
I missed Alan.
RIP 5/29/15 - I love you son.
Talk to DD and see if you can get one of their supper carbon fiber and Kevlar cones.
Supper ultra thin and supper strong.
Probably costs a very pretty penny.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Sounds Delicious,
On a serious note, i am still super stoked to see this thing play.
It's about $260 if I remember, I contacted a seller about them originally, I think CJ also told me how much their DC CF cones are, somewhat similar price I believe.
The one I have is a kevlar reinforced paper cone, so I'm not really sure how it's gonna stand up to it. It feels pretty rigid honestly, but could I do anything to add rigidity without adding a ridiculous amount of weight? I thought about fiber glass resin but I figure it would chip and crack off too easily, and not really add much rigidity if any at all.
Any ideas would be cool
I missed Alan.
can always fiberglass/resin the cone from behind if the front doesnt look like it would work or is treated with something that might keep resin from sticking.
If you get adventurous you could build your own flat-piston cone to allow more separation between spider levels for greater linearity ; )
Hammerdown... 1%
How close is the gap in terms of measurement ???
the gap between the pole piece and the voice coil ID and Top plate and VC OD ???
If it is more than 1 mm per side then you are good to go !!!!
For example
Pole Piece -> 75
VC ID -> 77
VC OD-> 81
Top plate -> 83
These are all assumptions to make my point clear !!
For example
Pole Piece -> 75
VC ID -> 77
VC OD-> 81
Top plate -> 83
I'm not quite sure, I'll check tomorrow, but if I had to guess I would say we are bordering just below 1mm between the top plate and coil, and it might be even smaller between the pole and coil, but that's only a guess. I'm assuming this based off the paper test and visual memory....
what can I say, I like to live dangerously.................................................that [gap < 1mm] thug life chose me.....
I missed Alan.
Well it's not pulp so I think there a lot more that would be able to adhere onto the back, and the front is the same too.
Also, concerning cone material, I know it has a huge effect on response, and can dramatically affect the linearity of the speaker as well as resonance. But I haven't used the info that I learned a while ago so I can't remember the differences and details between all of them, and how much shape affects them. Not to be confused with rigidity, the rigidity of the cone is everything, if it's flexing and bending then yeah it's gonna affect it, but as far as I remember if they (deep and flat cone) are equally as rigid and both have the same [Xmax times cone area] then the they produce the sound wave the same lol. Even though I know that's true, it's still always "perceptually wrong" in my village idiot method of thinking because I would think that volumetric displacement of air would be greater by the deeper cone compared to the flat cone, but stupid effective radiation area just says, "Hey brain, shut your mouth and stop thinking about cone depth, it's all about diameter fool." when I do displacement calculations.
But anyway, I never seem to remember the full technical details about deep vs flat cones and if one is better than the other, or if it really just depends..........
So back on track, if you know about cones, would you suggest keeping the kevlar reinforced paper, or go with a DD kevlar-infused pulp cone? The price is worth it if you think it would be better. Also keep in mind damping here, the pulp would without a doubt be better at damping than the cone I have now, but I'm not sure how much better or how much of a difference it will make because I've only studied the effects of damping on midbass and higher frequency speakers, not woofers.
It's only $44 and it's free shipping scheduled to get here on my birthday
http://www.ebay.com/itm/18-Digital-Designs-Kevlar-Pulp-Subwoofer-Cone-Foam-Surround-/290954255299
(P.S: STUPID NON-LINEARITY, I SHOULD HAVE GONE WITH THE 4" COIL AND LEFT YOU BEHIND, THE ERMAHGERD GETS 50mm OF LINEAR 1-WAY TRAVEL. THANKS ALOT FOR NOT ACCIDENTALLY SENDING 4" DIAMETER MAGNET SLUGS INSTEAD STUPID INTERNET! NOW I'M GONNA HAVE TO MAKE A NEO V.3 WITH A 4" COIL JUST TO BE SATISFIED)
I missed Alan.
Only read part of your last post.
4" coil with that tight of a gap wont help with keeping coil straight.
That gap is too tight. Plain and simple itll be great for a burp sub tho.
Not sure if any other amps will blow, but soundigital amps blow when the coil leaves the gap or hits pole/top plate, but their protect circut sucks
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
