Rockford96 Posted May 28, 2013 Report Posted May 28, 2013 I just built a new box for my truck its 3 re audio 10s on a boss amp:/ i know not great stuff but its what i have the box specs are 18.25 high 56width top depth 5.5 bottom depth 9.75 the pory faces up and is 10.5 wide 3.5 high and 22"long its about 12 for port area and i think its to much my last box was close to 10 per cube using pvc and it was alot louder and now it just doesnt sound right i dont want to scrap the nox if anything i just eill make a new top piece and new port so if you guys could help me out i would appriciate it Ive checked the subs wiring they are not out of phase all the connections are tight the box has no air leaks also My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Raptorman Posted May 28, 2013 Report Posted May 28, 2013 What's the box made out of? Also it seems that your box is roughly 2 cubes net. Those 3 10's are going to want around 3.75 cubes net. Port area is a tad on the small side too. Want around 14-16 port per cube for the slot port 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
deathcards Posted May 28, 2013 Report Posted May 28, 2013 i suggest trying a different amp? when you have the funds skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Raptorman Posted May 28, 2013 Report Posted May 28, 2013 no ^ Although he could definitely have a better amp, the box is pretty out of spec. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
deathcards Posted May 28, 2013 Report Posted May 28, 2013 no ^ Although he could definitely have a better amp, the box is pretty out of spec. yeah maybe that would be better first but then a better amp skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Skullz Posted May 28, 2013 Report Posted May 28, 2013 Just go to the fabric store and get a yard or two of cotton/poly batting and line the bottom and the sides and that will remove the hollow sound. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Rockford96 Posted May 28, 2013 Author Report Posted May 28, 2013 What's the box made out of? Also it seems that your box is roughly 2 cubes net. Those 3 10's are going to want around 3.75 cubes net. Port area is a tad on the small side too. Want around 14-16 port per cube for the slot port the box is made out of .5 mdf and its about .9 per sub and the manual for them calls for 1 cube so its close and the port is a straight port no bends in it its 8" outside of the box My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Rockford96 Posted May 28, 2013 Author Report Posted May 28, 2013 Im job searching now so as soon as i get one i plan on getting a sq/aq 1200 or a rockford bdcp My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Raptorman Posted May 28, 2013 Report Posted May 28, 2013 It's .9 per sub before displacements, and even less after displacements. I would give them 1.25 cubes per. And step it up to 3/4" MDF. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Rockford96 Posted May 28, 2013 Author Report Posted May 28, 2013 Im already at my max fir dimensions its in a single cab and the steering wheel is already on my lap the seats so far forward and sorry i dont have rorres now so the per sub was all from my head My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
