Chipmunk-Alero Posted June 1, 2013 Report Posted June 1, 2013 Hate to start a new thread on this but posted on the FRF and got no response. Vehicle is a 99 Ford Ranger. I've done big threes in the past but not sure if I've seen a positive running through the fuse box before. It hooked into a 175 amp fuse next to the box. Now, my question is does it have to run through the fuse next to the under hood fuse box and can I change it to another amperage? Can I go my own way with it or will it not charge right? Please help, Thanks. 2001 Oldsmobile Alero 4Dr GL2 - R.I.P.2006 Dodge Charger R/TJVC KDx40AudioQ 2200d Big 3 and KNU 1/0 Fi BL 15" (09 model) 4.2 cuft net @ 33hz(15.8 sq in per cube) 1999 Ford Ranger XLTPioneer DEH-6200btRockford Fosgate T400-4, T1500-1bdCP, T1 6.5" Components, RCA's, Distro blocks.1 Fi Car Audio BL 12 - 2.5 cuft net @31hz(16.8 sq in per cube)XS Power S3400, 2 KNU 1/0 runs and KNU Big 3. Build Log ----> http://www.stevemeadedesigns.com/board/topic/170878-99-ford-ranger-fi-rockford-xs-power/
Tarball Posted June 1, 2013 Report Posted June 1, 2013 Big 3 = 3 wires 1. positive wire from alt output to batt pos 2. negative alternator case to frame/chassis ground (clean sanded metal) 3. negative frame/chassis ground to battery negative add those wire to what is already there. use 1/0 preferably ofc - cca is fine if that is what you have already. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Markous Posted June 1, 2013 Report Posted June 1, 2013 this is how my '07 looks after i did mine. '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
Chipmunk-Alero Posted June 1, 2013 Author Report Posted June 1, 2013 this is how my '07 looks after i did mine. So u ran your own positive to alternator and didn't go through fuse box. Isn't that blue wire your alt run? 2001 Oldsmobile Alero 4Dr GL2 - R.I.P.2006 Dodge Charger R/TJVC KDx40AudioQ 2200d Big 3 and KNU 1/0 Fi BL 15" (09 model) 4.2 cuft net @ 33hz(15.8 sq in per cube) 1999 Ford Ranger XLTPioneer DEH-6200btRockford Fosgate T400-4, T1500-1bdCP, T1 6.5" Components, RCA's, Distro blocks.1 Fi Car Audio BL 12 - 2.5 cuft net @31hz(16.8 sq in per cube)XS Power S3400, 2 KNU 1/0 runs and KNU Big 3. Build Log ----> http://www.stevemeadedesigns.com/board/topic/170878-99-ford-ranger-fi-rockford-xs-power/
Chipmunk-Alero Posted June 1, 2013 Author Report Posted June 1, 2013 Big 3 = 3 wires 1. positive wire from alt output to batt pos 2. negative alternator case to frame/chassis ground (clean sanded metal) 3. negative frame/chassis ground to battery negative add those wire to what is already there. use 1/0 preferably ofc - cca is fine if that is what you have already. Not trying to sound like an ass but I'm not sure if you read the post. 2001 Oldsmobile Alero 4Dr GL2 - R.I.P.2006 Dodge Charger R/TJVC KDx40AudioQ 2200d Big 3 and KNU 1/0 Fi BL 15" (09 model) 4.2 cuft net @ 33hz(15.8 sq in per cube) 1999 Ford Ranger XLTPioneer DEH-6200btRockford Fosgate T400-4, T1500-1bdCP, T1 6.5" Components, RCA's, Distro blocks.1 Fi Car Audio BL 12 - 2.5 cuft net @31hz(16.8 sq in per cube)XS Power S3400, 2 KNU 1/0 runs and KNU Big 3. Build Log ----> http://www.stevemeadedesigns.com/board/topic/170878-99-ford-ranger-fi-rockford-xs-power/
Markous Posted June 1, 2013 Report Posted June 1, 2013 No i didn't go through the fusebox, i just re-used the old wire with the mickey mouse ears double ring terminal and connected it seperately. '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
Chipmunk-Alero Posted June 1, 2013 Author Report Posted June 1, 2013 So those red wires were factory right? That's how mine looks. And u added the blue going across the radiator? 2001 Oldsmobile Alero 4Dr GL2 - R.I.P.2006 Dodge Charger R/TJVC KDx40AudioQ 2200d Big 3 and KNU 1/0 Fi BL 15" (09 model) 4.2 cuft net @ 33hz(15.8 sq in per cube) 1999 Ford Ranger XLTPioneer DEH-6200btRockford Fosgate T400-4, T1500-1bdCP, T1 6.5" Components, RCA's, Distro blocks.1 Fi Car Audio BL 12 - 2.5 cuft net @31hz(16.8 sq in per cube)XS Power S3400, 2 KNU 1/0 runs and KNU Big 3. Build Log ----> http://www.stevemeadedesigns.com/board/topic/170878-99-ford-ranger-fi-rockford-xs-power/
Markous Posted June 1, 2013 Report Posted June 1, 2013 Yes they are, i just cut them, twisted them together and soldered on a 4 ga. ring terminal. The blue is my pwer wire from the alt. yes. '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
Chipmunk-Alero Posted June 2, 2013 Author Report Posted June 2, 2013 Thanks man I'm gonna do mine the same. Just out of curiosity where did you ground to? 2001 Oldsmobile Alero 4Dr GL2 - R.I.P.2006 Dodge Charger R/TJVC KDx40AudioQ 2200d Big 3 and KNU 1/0 Fi BL 15" (09 model) 4.2 cuft net @ 33hz(15.8 sq in per cube) 1999 Ford Ranger XLTPioneer DEH-6200btRockford Fosgate T400-4, T1500-1bdCP, T1 6.5" Components, RCA's, Distro blocks.1 Fi Car Audio BL 12 - 2.5 cuft net @31hz(16.8 sq in per cube)XS Power S3400, 2 KNU 1/0 runs and KNU Big 3. Build Log ----> http://www.stevemeadedesigns.com/board/topic/170878-99-ford-ranger-fi-rockford-xs-power/
Markous Posted June 2, 2013 Report Posted June 2, 2013 Grounded from battery to the motor on the same stud used by the factory and also from the alternator bracket to the passenger side strut. Might re-do that one on the strut though, not really sure what kind of metal to metal contact are there is there? I don't have a picture of the strut gounded but this is the alternator with everything hooked up. '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
